Old 07-29-2007, 08:27 PM   #1
Hmmm, where to begin.....
FBC72's Avatar
1997 25' Safari
Wasilla , Alaska
Low hot water pressure???
1996, 25ft Safari. For some unknown reason, we have very low hot water pressure. The cold water pressure is fine though. The hot water pressure is less than half of what the cold pressure is, and this only started this year, last season it was fine. I double checked the hot water tank bypass valve, and all appeared right. Any suggestions???
FBC72 is offline   Reply With Quote
Old 07-29-2007, 09:38 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Sometimes a piece of corrosion from the hot water tank or one of the valves comes loose and jams the line, restricting the flow. sometimes backflushing with a garden hose from one of the faucets will blow it back into the tank.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-29-2007, 10:49 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
In addition to Excella's suggestions, you might have a defective check valve, which is usually located on the water heater's hot water output fitting. I would remove the check valve, re-connect the PEX and try the hot water. If your pressure is normal, or noticeably better, then it is the check valve and it should be replaced.
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
hot water heater Mary Water Heaters, Filters & Pumps 2 08-12-2002 09:15 AM
Faulty Emerson RV E-330-5 Hot Water Dispenser winner Water Heaters, Filters & Pumps 4 08-02-2002 02:07 PM
Leak in hot water heater tank Rog0525 Water Heaters, Filters & Pumps 8 06-10-2002 02:10 PM
