Old 08-26-2015, 09:00 PM   #29
1998 25' Safari
Greensboro , North Carolina
Originally Posted by streaminwild View Post
Orin, Your pictures are worth a thousand words. Great job with close-ups which reminds me......I need to make an appointment with my dentist. Gregg
Hope he uses something a little better than the scribe in the photo..
By the way - If someone does this repair only use one drop of glue and put the rubber washer on the valve stem "tit" with a twisting motion to spread the glue.
2015 Ford SuperCab 2.7L Ecoboost V6
1998 25B Safari
"It is well that war is so terrible -- lest we should grow too fond of it." Gen. R.E. Lee CSA
762x51 is offline   Reply With Quote
Old 04-25-2016, 01:46 PM   #30
1997 25' Safari
Elgin , Arizona
Thanks for your persistence with this problem and finally getting to the fix. Had the same problem this weekend with my 97 Safari and a $1 tube of superglue did the trick.
caseypris is offline   Reply With Quote
Old 04-25-2016, 02:24 PM   #31
1998 25' Safari
Glad that worked for you and if you read the whole thread you'd see all the hoops I jumped through to finally get to the problem. @streaminwild made the suggestion that I followed to get to the bottom of the problem. Using super glue was the only modification to his suggestion that I came up with.
1998 25B Safari
Old 04-25-2016, 04:49 PM   #32
1999 30' Excella 1000
small town , Maryland
The comradery here is 2nd to none. We all suggest ideas that hopefully, helps someone down the line. I like the phrase ''passing it forward''. Weather it's paying for a police officer's, military personnel, or homeless persons meal anonymously. Or rewarding acts of kindness that you rarely see in the city. This hobby gives me the most pleasure in life. Thankyou caseypris for thanking us. You made our day
streaminwild is offline   Reply With Quote
Poor hot water flow - new Airstream AirFoiler Water Heaters, Filters & Pumps 4 05-04-2015 11:01 AM
hot water flow in shower tapers off k5uuu Sinks, Showers & Toilets 4 04-30-2014 06:50 PM
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 01:08 AM
Please Help! Magic Chef Countertop stove low flow blazeff13 LP Gas, Piping, Tanks & Regulators 4 08-26-2011 09:55 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
