Old 07-19-2015, 12:01 AM   #1
worried...happy...wo...ha
Knuff's Avatar
2015 25' FB International
Menlo Park , California
Loud water pump - why?
Our 25FB, 2015 is a great tt. We are happy and have not a lot of complaints about layout, quality, design, but there is one issue that is simply not making sense. The issue is the water pump. Why does this thing have to be so loud? For 80K+, I would expect something that is whisper quiet, not waking up everyone when somebody needs to use the bathroom in the middle of the night. Are these loud pumps really state-of-art? Any alternatives?
Knuff is offline   Reply With Quote
Old 07-19-2015, 02:08 AM   #2
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
I am sure if it is a defective pump it will be warranted. 1st depending on the noise, if it internal to the pump, could be a defect. Otherwise could be a vibration problem, whereas the pump needs to be mounted properly with rubber grommets to the mounting surface. Find the pump and investigate, good luck. It that fails see a dealer.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 07-19-2015, 02:29 AM   #3
mandolindave's Avatar
They are loud
I find it useful…You know if there is a leak. You can tell when you are running out of water.
You could turn the pump off at night. The water in the bowl would give you one flush. Keep a jug of water in the bathroom.
mandolindave is offline   Reply With Quote
Old 07-19-2015, 05:46 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The noise is probably the pump or strainer assembly touching something when it's running. Look closely to see if there is anything touching the pump, such as pipes, wires, even a piece of cabinetry. The OEM pumps are usually quiet.
Old 07-19-2015, 06:06 AM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Is this your first RV. They are all noisy ito a certain degree except for pumps locacated in basement storage of Class A/C far below the living area.
Kelvin
Old 07-19-2015, 06:20 AM   #6
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
The pump in my unit is whisper quiet except when I have not tightened the intake at the pump connection after winterizing. A small air leak on the intake side will result in a racket. Jim
Jim Flower is offline   Reply With Quote
Old 07-19-2015, 07:57 AM   #7
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
On my 25', the shelf holding the water pump came loose. Only a couple of short screws were holding it. A couple of longer screws tightened it up and cut the noise down significantly.
2012 Dodge Durango Hemi/AWD
Old 07-19-2015, 11:25 AM   #8
2007 25' Classic
Hutto , Texas
It's possible that it's not the pump but one of the pex lines. If they are not completely anchored they can vibrate against the trailer somewhere.
Wanderer2604 is offline   Reply With Quote
Old 07-19-2015, 12:53 PM   #9
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
An Accumulator Tank can be added to the system as a buffer to reduce cycling every time the water is used.
Anyone have experience with one of these? Does it also help quiet the system when the pump is running?
Greg
greghoro is offline   Reply With Quote
Old 07-19-2015, 02:24 PM   #10
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
I mounted our WP on 'rubber feet' much less noise/vibration.
Question.....why is the WP on at night? (or when no-ones in the trailer)
I woke up in the middle of the night to a running pump and a flooded bathroom.
Lesson learned...cross threaded fitting during the build, split under pressure.
Old 07-19-2015, 06:02 PM   #11
Knuff's Avatar
Thank you for all the good suggestions. I think that nothing is wrong with our pump, perhaps it is vibrating against something and I will investigate ways to make the beast more quiet. In our previous tt (a 20FC), the noise level was the same. Also in our converted pop top VW years ago. I am just thinking that with all the technologies available, why does the pump has to be intrinsically loud AND why is the factory installation not paying attention to vibration. Well, I guess it will be time for rubber feet. Also good point to check the connections to avoid floods - thank you Bob for the images; very educating.
Old 07-19-2015, 07:12 PM   #12
Captain Hank's Avatar
2007 27' Safari FB SE
Summerville , South Carolina
Robert,
Will you post or PM me where you bought the rubber mounting feet for you pump.
Captain Hank is offline   Reply With Quote
Old 07-19-2015, 07:23 PM   #13
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Welcome to the good life! I purchased a Shur-flo pump silencer kit. It is not silent but it is quieter. Of course this only matters when boon docking (without hookups) I do not use the pump when on city water. Bob's solution may work as good, dunno.
http://www.adventurerv.net/shurflo-p...source=Froogle
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 07-19-2015, 07:43 PM   #14
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I made my own flexible water pump hoses and installed an accumulator. It is so quiet now.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Shur-Flo pump is Too Loud star kitty Fresh Water Systems 19 09-28-2011 10:20 AM
12 V water pump too loud Hook Shot Water Heaters, Filters & Pumps 4 09-04-2010 07:36 PM
2008 17' Safari Sport Loud Water Pump Dale Monroe 2008 Safari SE 5 08-22-2010 07:57 PM
Loud water pump quiets down ESCAPE POD Water Heaters, Filters & Pumps 3 03-02-2010 05:28 PM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
