Old 07-19-2015, 07:52 PM   #15
Manheim , Pennsylvania
Same experience here, with it being loud. I stuffed a little insulation in the cavity to mufffle it. That helped a little bit. It is ridiculous that the trailer has all these noise issues! Water pump, Fridge fan and converter fan all very loud stock new. If I ruled the world things would certainly be different.
Jukeboxfun is offline   Reply With Quote
Old 07-19-2015, 08:40 PM   #16
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by Captain Hank View Post
Robert,
Will you post or PM me where you bought the rubber mounting feet for you pump.
Capt,
The mounts I used,(pictured), were for mounting an electric fuel pump, something saved from my knuckle busting daze. The male mount screws on both ends required an extra mount block under the water pump.
If I was doing it again I would use a soft rubber base mount,, (the new one listed in this link), it can be mounted directly to the existing platform.
More info
Old 07-19-2015, 10:08 PM   #17
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Thanks for the link Bob. The site talks about an "e-store" but it does not look like they sell online. Now that I know what I'm looking for I will try and find a source online.
Thanks again
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 07-19-2015, 10:13 PM   #18
Arcticfox's Avatar
Central , Canada
B the way. Does anyone have a recommendation for an accumulator?
Doug
Old 07-20-2015, 03:48 AM   #19
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Doug
I installed one of these in my Safari. It worked flawlessly for 15 years. Google, "accumulator tank, Home Depot ".
8.5 in. W x 11.5 in. D x 8.5 in. H Pre-Pressurized Steel Water Expansion Tank.
I stuffed it up under the sink. Jim
Jim Flower is online now   Reply With Quote
Old 07-20-2015, 04:27 AM   #20
Thanks again
Cheers
Doug
Doug,
You can order from that site.
From the "more info" link I posted.
Click on "view & buy products" under the picture.
Scroll down & click on the catalog # you want & order.
Old 07-20-2015, 07:36 AM   #21
Arcticfox's Avatar
Central , Canada
Thanks Jim - I will go and do a search for it....
Cheers
Doug
Old 07-20-2015, 07:42 AM   #22
Arcticfox's Avatar
Central , Canada
Thanks bob - I will look into it today and get something ordered. I see there is two different sizes with that product. Any advise on what one to order? Right now I'm assuming bigger will be better?
Doug
Originally Posted by ROBERT CROSS View Post
Doug,
Old 07-20-2015, 07:52 AM   #23
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I have the Shurflo accumulator tank under my kitchen sink mounted vertically next to the Delta water filter. The instructions state you can place it anywhere on the plumbing system and this is the only place that was easily accessible for mounting and for winterizing. I patched it in with a T fitting. I don't think it makes my Flojet any quieter, all it does is delay when the pump starts up to build the pressure back. I can usually do a short flush and the pump won't come on. The Flojet documentation advises an accumulator is not necessary. When the pump is on and needs to build pressure it seems to take longer than what a remember before installing the accumulator.
I don't think I could put those rubber feet on my pump. It would raise the pump to where the inlet hose might not connect correctly. The Floject has clip in connections, not screw in connections. The output side is a flexible hose. Not sure if that was standard or the previous owner had it installed. My water pump is partially under the fridge and closet a real pain to get to. I can't see how I could work on the PEX pipe using the required tools to crimp new fittings if I decided to make modifications to the pump's location.
I've also wrapped foam pipe insulation around some of the PEX pipe in the water pump area to pipe that are rubbing each other or laying against other plumbing. I little bit is on the pipe going to the toilet.
Kelvin
Old 07-20-2015, 08:52 AM   #24
Sanford , North Carolina
I have the same issue with my 27ft EB. Called Airstream dealer. He said just get some antifatigue foam mat or something similar and mount it to the floor using that. I haven't done it yet, but will here in the near future.
Another thing to note, check your shower water filter. If it is dirty it might make the pump constantly have to run. There is a video on YouTube on how to check it. Hope this helps.
Cheers, Ryan
vwklick is offline   Reply With Quote
Old 07-20-2015, 09:42 AM   #25
dalemonroe's Avatar
2008 16' Safari
Portland , Oregon
Our pump was noisy because the pipes were slaping against the side of the trailer. I attached a two foot long rubber tube to a can of rigid poly urethane insulating foam and shot foam in around the pipes where I couldn't reach. That cured it about 80 percent, then I added an accumulator. It's quiet now.
dalemonroe is offline   Reply With Quote
Old 07-20-2015, 11:20 AM   #26
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Picture.
Hi, here is a picture of my water pump with my home made flex hoses and my accumulator. It is very quiet and works very well.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-20-2015, 11:42 AM   #27
KJRitchie's Avatar
2008 25' Classic
Airstream designed your water pump access wrong. The pump should be further back in an out of the way place covered with heater ducts, PEX plumbing and wiring. I wish my water pump access was like yours. I have to unscrew and access panel in the cabinet under my fridge to get to my water pump.
Kelvin
Old 08-23-2015, 01:56 PM   #28
Some Guy
djarrett's Avatar
2018 28' Tommy Bahama
Nashville , Tennessee
On our 25' Eddie Bauer, the water pump sounded like a 36" concert bass drum with a long roll being played on it.
Turns out the pump was screwed directly into the floor in the area under the hallway closet. I loosened the 4 screws holding the feet to the floor. Lifted it slightly, and slid a $2.00 black mouse pad under it and then screwed the feed back down through the mouse pad. Now, the pump is almost silent. You have to listen carefully to hear it.
A $2 mouse pad as an isolation mat. Why couldn't AS simply do this simply thing when assembling?
D
The Jarretts
Nashville, Tennessee
2018 27' Tommy Bahama
2015 F250 TV-Petrol
WBCCI # 22342
djarrett is offline   Reply With Quote
Shur-Flo pump is Too Loud star kitty Fresh Water Systems 19 09-28-2011 10:20 AM
12 V water pump too loud Hook Shot Water Heaters, Filters & Pumps 4 09-04-2010 07:36 PM
2008 17' Safari Sport Loud Water Pump Dale Monroe 2008 Safari SE 5 08-22-2010 07:57 PM
Loud water pump quiets down ESCAPE POD Water Heaters, Filters & Pumps 3 03-02-2010 05:28 PM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
