Old 04-01-2004, 05:46 PM   #1
Rising Sun, MD
Location of water heater bypass
Don't mean to be ignorant, but can someone tell me where the water heater bypass is on a '84 Soveriegn '27? Also, could use some help figuring out two small valves located just downstream from city water intake. Are they to isolate fresh water tank? If not, what do they do? Thanks for any help!
buckeroo2 is offline   Reply With Quote
Old 04-01-2004, 08:25 PM   #2
I don't know about the 84 sovereign but on my 92 sovereign the water bypass is under the bed. (terrible location) I had it for several years before I found that it had a water bypass valve. The two valves you mentioned may be the hot and cold water drain valves. They are helpful to winterize your unit.
Wayne
wayner1239 is offline   Reply With Quote
Old 04-02-2004, 06:43 AM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
On both my '03 Bambi and '04 Safari, it was located under the bed. It ususally, I have found on at least the newer units (that I have seen), is near the water heater.
Eric
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Water heater bypass installation Craig Water Heaters, Filters & Pumps 4 04-05-2003 04:13 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
water heater bypass tomb 1984 - 1989 Sovereign 1 11-22-2002 01:04 PM
Water heater bypass niftypkg Water Heaters, Filters & Pumps 0 05-15-2002 05:38 PM
