Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 07-26-2002, 02:01 PM   #1
susan martin
Profile:
lighting water heater
I have a 1967 Carvel (Littlle Duke) which I am restoring. I can't figure out how to light the water heater with the Bowen/Atwood shroud attacheed. There is no way to get to the control of the lighting point through the access door because of the heat disperser on the inside. The only I can light it is to take the shroud off completely which is ridiculas. Is it possible that the heat disperser was added by some nut?
I will have some original parts like the interior lights and the Thetford 1400 toilet available if anyone is interested.
Sue
susan martin is offline   Reply With Quote
Old 07-27-2002, 08:13 AM   #2
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Without seeing it I am guessing. Someone probably added a shield for just the opposite problem you are having. To keep the wind from blowing it out. It has been commonly done for this purpose. Can you reach it with one of those long lighters that are used to light fireplaces or BBQ pit fires. I keep a couple of those around just for this purpose and lighting my houses gas water heater.
Can you post a picture?
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 07-27-2002, 10:13 AM   #3
Fatt Ratt
Fatt Ratt's Avatar
Profile:
lighting pilot
Hey y'all,
I work with alot of gas pilots and what we use to light them with is a Bernz O Matic pistol grip torch. This attachs to a small propane fuel cylinder, all can be found at ACE or Home Depo. This is great for hard to get at pilots. I never go camping with out one, this thing starts anything a blaze. The torch has an adjustable flame from 3/4" to 12" long. Do not use this torch if you have not leak tested the stove, water heater, ect... before lighting the pilot. - Ray
Cut to suit, Beat to fit, Paint to hide!!
Fatt Ratt is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Lighting Water Heater & FNG Mike76251 Water Heaters, Filters & Pumps 4 09-07-2003 10:11 PM
Lighting Hot Water Heater hhuber Water Heaters, Filters & Pumps 14 04-01-2003 09:31 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
