Old 05-15-2005, 07:05 PM   #1
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
Leaking hi pressure water heater hose
After noticing a soggy carpet in front of my sink area, I found a pinhole jet of water hissing out of this hose at the pressure fitting. Is this something an RV shop has to do, or can a qualified plumber just come over and "get 'er done"?
This happened after hooking up to a campground water source, although after disconnecting and using the on board water pump it still leaked out.
Since this was in Anaheim, I was referred to a mobile RV repair shop, but after 2 days they never called me back. Now I'm back home and prefer to have it done here rather than take it to a shop. Thanks for any info.
Name:	hi press. hose.JPG
ID:	12144   Click image for larger version
Name:	water damage.JPG
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 05-15-2005, 07:28 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Just about anybody could fix it, I suspect. If you could include a (close-up) picture of the leak itself, I'll bet we could guide you through getting the necessary part(s) at the local Home Depot and fixing it yourself!
Lynn
WBCCI 21043
Old 05-15-2005, 07:30 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Is that grey thing before the elbow a clamp of some kind? If it is, you can probably remove the clamp, cut off the offending piece, and re-clamp the hose to the elbow.
It is hard to see exactly what it is in the photo.
Old 05-15-2005, 07:36 PM   #4
That almost looks like a PEX crimp. I have seen some of them that are silver in color before.
Anon is offline   Reply With Quote
Old 05-15-2005, 07:46 PM   #5
What you have there is a polybutylene fitting. You probably have many of them, and they will all develop cracks, unless they blow completely apart. There is a lot of information on polybutylene plumbing and its shortcomings in the archives.
Mark
'85 Sovereign, 25'
Old 05-24-2005, 02:31 PM   #6
Astrodokk's Avatar
Hi,
For some reason I am not getting an email stating replies to this thread.
How do I drain the water heater? The manual doesn't say, and I'm gonna fix this leak but don't want alot of water all over the place. I've opened the faucets for hot and cold, under pump pressure, and no water comes out now, although a plumber told me that there will still be water in it. Does it even have a drain plug?
Old 05-24-2005, 04:27 PM   #7
Well Preserved
1993 21' Sovereign
Originally Posted by Astrodokk
Hi,
Almost all water heaters have a drain at the bottom of the tank. In the case of the water heaters in our trailers, this is usually a plastic threaded plug on the outside of the water heater, behind the outside door.
Old 05-24-2005, 08:21 PM   #8
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Rivet Drain tank ...
Pull the sacrificial zinc plug out. It may need servicing anyway.
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 06-05-2005, 10:13 PM   #9
Astrodokk's Avatar
Thanks everyone for input. As I wouldn't know what the best materials to use, I called a plumber and he came out within an hour and had it repaired! It took about 45 minutes, and he uswed what you will see in the pic. He said the old polybutelene pipe had namy probs with it years ago and id not in use anymore. He gave me a lifetime warranty on this one. I don't remember what it's called, sorry. Cost me a Ben Franklin out the door. Well worth it in my opinion, since it would have cost me materials and alot of time!
Name:	leak repair.JPG
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
