Old 06-30-2008, 08:15 PM   #1
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
Late Model Faucet Filter...
Howdy...
I have a Safari with the LS package which includes the Moen water filter faucet that is just under two years old. The "replace" light just started blinking at me so I dissasembled it to see what all was inside. WOW, the filter is big, way larger than I thought.
So, I was wondering if anyone has replaced thiers, where did you get it? I found it from Moen online, but surely somebody sells these things at home centers or plumbing supplies?
Anyone replaced theirs??
SafariSS is offline   Reply With Quote
Old 06-30-2008, 08:39 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Here's this one at Lowes. Not sure what model you were looking for. Interesting it's about the same size and price as the Everpure used in the older models but just a hair pricier.
Moen®
Moen ChoiceFlo™
Replacement Filter
Item #: 113116 Model: 9501$32.96
Old 06-30-2008, 08:53 PM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by SafariSS View Post
Howdy...
My light came on two. I used the filter so in-frequently so I went to the local plumbing supply and ordered some. I found the battery causing the blinking . removed it and threw it away. no more blinking light problem.
Michelle TAC MT-0
Sarah, Snowball
Old 06-30-2008, 09:02 PM   #4
SafariSS's Avatar
2005 30' Safari
Thanks Gary..
Wow, 32 bucks. I probably will cruise by lowes cause I need one, but will order a couple online as I found some for 22 bucks.
thanks for the replys...
Old 06-30-2008, 09:41 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We placed ours recently. We had bought a two pack from Moen online. That's the only place that I was able to find them. The unit also has a watch battery in it. We had to replace it before the filter.
Brian
SuEllyn & Brian McCabe
Old 06-30-2008, 10:08 PM   #6
_
...Anyone replaced theirs??
sure, about every 9-12 months, supposedly good for 200 gallons of filtering, i use it for coffee water.
depends on the moen model number but a/s carries them at the factory store...
or ya can buy'em on line, for a few $ less...
here and other places...
for 15-20$.
on the classic line, they blink green when in use and until time to replace then go to yellow and red...
the model is a 601? the filter is IN the fixture, shown in the right pic, filter unit is on the left...
here are the installation instructions...
http://www.filtersfast.com/Moen-601-Manual.pdf
the 'choiceflow' model noted above is an UNDER counter filter, similar in design to the old everpure line...
cheers
2air'
Old 07-01-2008, 06:28 AM   #7
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Does my 2007 Safari LS use the battery? If so, where does it go?
I couldn't find a spot to install the battery so I just saved it for the next time something like a garage door opener needs one.
Thanks!
SilverCottage is offline   Reply With Quote
Old 07-01-2008, 08:00 AM   #8
moosetags's Avatar
The Moen filter faucet takes one of those wafer batteries about the size of a nickel. I think it's a CR2032. The battery it located in the faucet head near where the filter hooks on. There's a little slide door that accesses the battery compartment.
Brian
Old 07-01-2008, 09:49 AM   #9
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I replaced mine and bought a few for spares. They are a bit cheaper at Faucet Depot...
FaucetDepot.com - Moen 601 MicroTech (R) 600 Classic Replacement Filter
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Late Model Vehicle Tow Ratings Andy R Tow Vehicles 2 07-20-2008 06:11 PM
What about a late model Suburban? connorsa Tow Vehicles 3 10-26-2007 11:03 AM
late model toyota landcruiser as tv mikersmgm Tow Vehicles 11 05-11-2007 08:32 AM
2006 Classic Moen Faucet Filter Pappy Water Heaters, Filters & Pumps 18 10-02-2006 10:54 AM
Anyone own a late model AS motorhome? idahosafari General Motorhome Topics 14 10-23-2004 12:18 PM
