Old 04-09-2010, 09:58 AM   #1
2014 30' International
Englewood , Colorado
Kitchen sink water filter help needed
So, I just bought a 2007 Safari and got the correct Moen water filter hooked up to the kitchen sink. It looks like there should be a hose from the water source into the filter, and this is missing. what is there is just a small hose from the top of the filter that runs to the filter on/off switch.
Does anyone know if I am right or not about 2 hoses needed? If so, what is the best way to run a hose from the water line to the filter?
Thanks!
Marklar is offline   Reply With Quote
Old 04-09-2010, 11:47 AM   #2
Never mind, I found the install instructions online, I can take it from here. Thanks anyway, folks!
Delta Under Sink Water Filter evanskl Water Heaters, Filters & Pumps 0 05-22-2009 11:07 AM
Kitchen Sink Hot Water wlgilbert40 Fresh Water Systems 6 05-04-2009 10:05 AM
under sink water filter advise Safari64 Water Heaters, Filters & Pumps 3 04-08-2009 07:28 AM
Under sink drinking water filter wacnstac Water Heaters, Filters & Pumps 7 04-05-2006 03:01 AM
Need a Water filter under sink w9det Water Heaters, Filters & Pumps 7 06-29-2005 06:15 AM
