Old 04-20-2014, 09:00 AM   #1
thinktankair's Avatar
1961 16' Bambi
grass valley , California
Keeping the Bowen shroud on an Atwood water heater.
I have come across many solutions to keeping the old shroud on my 1961 Bambi when I install a new Atwood water heater. Is the one pictured the best? I still haven't figured out how it will drain right. Advice?
Name:	ImageUploadedByAirstream Forums1398005983.214045.jpg
thinktankair is offline   Reply With Quote
Old 04-21-2014, 02:03 PM   #2
1961 16' Bambi
Any one have info on this question?
Old 04-21-2014, 02:21 PM   #3
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Attachment 210077
If you don't want to just open the plug and let it go you can cut a "T" into the fill line inside and put a tap and line through the floor.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
New water heater vs attempted resurrection of a Bowen/Atwood G6A2 Savage68 All Argosy Trailers 3 06-20-2013 09:11 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Bowen/Atwood LP to Atwood LP/ELEC./DSI? 65 overlander Electrical - Systems, Generators, Batteries & Solar 9 12-05-2005 06:10 PM
New Atwood water heater old Bowen door vent problem 63air Electrical - Systems, Generators, Batteries & Solar 0 08-22-2005 02:56 PM
Atwood Bowen anode rod? Moonshot Water Heaters, Filters & Pumps 3 11-11-2003 07:37 AM
