03-29-2011, 05:08 PM
#21
2004 19' International CCD
Los Angeles
Its wierd to me that everyone is into JB Weld instead of Marine Tex. Must be because it is more common. Is JB Weld safer for food-grade water sources than Marine Tex or something? If not Marine Tex is a superior product to JB Weld in my experience. I have repaired radiators, engine blocks and more with Marine Tex. Marine Tex will fix almost anything properly applied and is as easy to work with as JB Weld.
If Marine Tex wont fix it, it needs to be welded. I order Marine Tex from West Marine.
04-03-2011, 04:07 PM
#22
Corona
Originally Posted by Stickbug
Thanks all for your input and ideas. I have one last shot to try with the JB weld. My assessment is that it's too thin to withstand the water pressure under heat. I used a steel can lid to reinforce one section and that worked great, but it gave out in another area where the aluminum weld has failed. If that doesn't work, I think I'm going to order a new unit. I'm not sure I could remove enough of the JB weld down in the crack to make the weld trustworthy. I'll keep you posted.
A 38 year old water heater, should simply be replaced.
A patch is always a patch, and if that fails on a trip, you will invent more bad words.
Replace it and be done with the issue.
04-03-2011, 04:30 PM
#23
1977 25' Tradewind
Waskesiu Lake
, Saskatchewan
Originally Posted by klattu
Is it worth the risk?
If JB leaks after a few days...imagine the damage to floor etc.
Amen klattu. I believe "Mickey Mouse" repairs ( ) more often than not, give "Mickey Mouse" results ( ). Time spend trying to repair it could be better spent replacing it... and you won't be spending the dollars on quick-fix products.
Just my thoughts...
Kevin
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
01-15-2023, 04:19 PM
#24
Zavalla
Originally Posted by LadybugT
So what was the last outcome???
01-15-2023, 04:54 PM
#25
1994 34' Excella
Warren
, Manitoba
Do it once, do it right! Less money, frustration, aggravation, and often less time!! JMHO from experience.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
01-15-2023, 05:32 PM
#26
diesel maniac
Airstream - Other
Tucson
, AZ
We may never know, Stickbug has not been here for 12 years, went MIA shortly after this thread started.
Brian
