Old 04-30-2007, 10:41 AM   #1
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Jabsco strainer Par Pumpgard
Over the weekend I noticed the plastic cap on the strainer for the potable water supply was broken.
It is made by Jabsco Strainer Par Pumpgard Model 36400-0000.
Where can a new one be purchased? or is their another product that can be substituted?
crispyboy is offline   Reply With Quote
Old 04-30-2007, 10:45 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
I found a new one exactly like it at West Marine - Make Boating Better with New Boating Gear from West Marine -- I'll have to browse there before saying it's still available.
5 meter Langford Nahanni
Old 04-30-2007, 10:52 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
This is the new version of what you have, available from Jabsco. (this is their pic as well)
JABSCO Pumpguard In-line Strainer
$9.95
ITT46400-0002
Kit Pumpguard In-line 1/2"HB (13mm) SS ID hose. Prevents unnecessary pump breakdowns caused by particles in the water. Transparent housing allows instant inspection. Quick, in-place, cleaning of the 40 mesh stainless steel screen.
Old 04-30-2007, 10:53 AM   #4
I did find a different type of filter at West Marine -- same as Terry's above. But I found a number of images like my Argosy's filter from suppliers at Google Image Search and inserting jabsco pumpgard in the search field. The function is simple enough. You probably couldn't go wrong with what Terry shows.
Old 04-30-2007, 11:01 AM   #5
1976 25' Caravanner
Campton , New Hampshire
Last I knew (2004) the plastic cover was still available thru most RV dealers , pn 44070-0000 . Good luck
ticki2 is offline   Reply With Quote
Old 04-30-2007, 11:01 AM   #6
Well Preserved
1993 21' Sovereign
And at $9.95, it is probably one of the cheaper parts you will be putting on your Airstream.
Old 04-30-2007, 01:16 PM   #7
crispyboy's Avatar
1994 30' Excella
thanks everyone, I'll put my phone and computer to work.
Old 04-30-2007, 01:43 PM   #8
BTW -- I figured out the clear outer shell on mine had cracked due to inadequate winterizing. It's not desirable to put RV antifreeze in the fresh water tank -- too hard to flush out. You know where the strainer is now. Install a bypass valve for winterizing between it and the water tank. That should protect the water pump too.
pump not working... Chuck Water Heaters, Filters & Pumps 23 05-16-2007 09:44 AM
Par Bond silverlassie Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 03-03-2004 03:54 PM
What size kitchen sink strainer? RonJudi General Motorhome Topics 4 02-19-2004 12:06 PM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 12:22 PM
Water Pump Craig Water Heaters, Filters & Pumps 7 10-18-2002 09:26 AM
