Old 02-21-2015, 09:46 PM   #29
2007 22' International CCD
Probably the best explanation of the possible root cause. Makes sense on the timing. We don't get pump runs with our tankless HW heater, but did with the old Atwood 6 gallon...
KE4GNK/AE
Old 02-22-2015, 11:44 AM   #30
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
I reject your theory, and once again advance mine... We need to convene The Committee for the Advancement of Water Pump Cycling Possibilities and settle this thing the right way, with a heated round of Rock 'Em Sock 'Em Robots. Expanding air in a water heater... Preposterous! It's the check valve, by cracky.
-Red, being ornery...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 02-22-2015, 12:04 PM   #31
Meh. I just keep it switched off when I'm sleeping....
KE4GNK/AE
Old 02-22-2015, 12:16 PM   #32
Panama Red's Avatar
Obrien , Florida
Oh sure, take the easy way...
-Red, still ornery...
Most campgrounds, actually every campground, that we have been to in The LoveStream has had water hookups, so the pump is off anyways. When we camp it in the yard, I'll leave it on all night, but turn it off when we're away from the trailer.
Old 02-22-2015, 11:45 PM   #33
I'm a bit of a light sleeper, and odd machinery noises wake me right up, as well as sudden silence. It's an ex-Navy thing I've never outgrown. So I tend to set stuff into a known safe state if I can. Shutting off water pump and water heater (before we went tankless) is normal procedure. Since we usually camp connected, it's not an issue.
Rich, for whom running water wakes me right up, and I run towards the sound to investigate.
KE4GNK/AE
Old 02-23-2015, 09:02 AM   #34
Panama Red's Avatar
Obrien , Florida
I'm so twitchy at change in noise levels when I sleep, that I have to run a fan, or the A/C unit, or some kind of set background noise. Otherwise EVERY little noise wakes me up...
I was just picking a little, because I found it humorous that this thread went from "Why does my pump kick on once every six hours" to "Whether or not I should leave my pump on"... Not the greatest thread transmogrification, but a good one none the less!
-Red, learning big words from Calvin and Hobbes...
fan operates, but compressor won't kick on tinsltootsie Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-14-2017 03:25 PM
How to kick the mice out... cclarkego Off Topic Forum 43 10-01-2013 12:05 AM
I need a kick in the rear!!!! rebel beck Our Community 6 04-15-2007 10:05 AM
Dometic Silhouette Won't Kick in on Propane greenie3754 Refrigerators 4 08-14-2006 06:59 AM
