Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 06-25-2006, 06:04 PM   #1
dickwhite1
Profile:  1969 21' Globetrotter
Gilroy , California
Is DSI 12v or 120v?
Have chosen Atwood 6 gallon with DSI to replace water heater in 1969 Globetrotter. Do I need to run 12 volt or 120 volt wire to the new water heater to provide the "spark"?
Rookie struggles on!!!
dickwhite1 is offline   Reply With Quote
Old 06-25-2006, 06:15 PM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  L.A., Dammit , California
It should be 12 volts. Every one I have seen has had 12 volts dc.
Old 06-25-2006, 06:21 PM   #3
SafeHarbor
Round on both ends
SafeHarbor's Avatar
Profile:  1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Dick,
The heater needs 12 VDC to operate the ignitor. You'll need to decide where to mount the switch in the bathroom, too. I used a coathanger to fish it up into a plastic cabinet and used the template to cut an opening for the switch. I'm reasonably pleased with the way it came out.
Good luck. Take your time, and you'll be fine.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Battery Monitor Les Gilliam Electrical - Systems, Generators, Batteries & Solar 11 10-07-2002 09:13 AM
12v vs 120 jane babinski Electrical - Systems, Generators, Batteries & Solar 13 09-30-2002 10:23 AM
12V question uwe Electrical - Systems, Generators, Batteries & Solar 16 09-05-2002 02:14 PM
essential tools maznblu On The Road... 14 07-08-2002 03:23 PM
12V trouble.... Chuck Electrical - Systems, Generators, Batteries & Solar 8 07-06-2002 05:57 AM
