Old 10-16-2007, 05:40 PM   #1
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
if my water heater...
my 71 safari bowen water heater is VERY hard to turn on and off-almost need a pair of pliers to do it!-does tis mean that the main control should be replaced?--or can it be lubed??-thanx for your help!--jim from mich
jamesardis is offline   Reply With Quote
Old 10-16-2007, 06:23 PM   #2
The Flintstones's Avatar
1970 27' Overlander
Houston , Texas
Mine was that way, very stiff. I used WD-40 and it loosened up and has been fine since with an occasional spray but yours my be beyond that and need replacing.
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 10-16-2007, 07:06 PM   #3
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
Smile
thanx flint I wondered if it was possible to get the wd40 into the area that needed it--I will give it a try--thanks--jim
Old 10-16-2007, 07:06 PM   #4
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
Question
graphite maybe??
Old 10-18-2007, 05:30 AM   #5
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
wd works!--thanx flint!---jim
Old 10-18-2007, 07:47 AM   #6
1970 27' Overlander
Houston , Texas
Glad it worked for you to.
James
____________
1970 Overlander
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
Water Heater & Water Tank mgordon Water Heaters, Filters & Pumps 23 01-15-2003 06:58 PM
