Old 01-12-2015, 12:03 PM   #1
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
HWH heat exchanger
I'm debating between a tankless and a 10 gallon Atwood with heat exchanger. I feel like there could be some fun things to do with the heat exchanger. Can you tell me about them? Is it possible to use the heat exchanger in lieu of a tank heater? What else can we do with it? Can you get an on demand hot water heater with a heat exchanger?
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 01-12-2015, 12:44 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Typically, the heat exchanger in a RV water heater is to allow the engine coolant to heat domestic water while traveling down the road.
There is a thread here somewhere that describes installing a exchanger equipped water heater in a trailer, then using it in "reverse", to provide in-floor radiant heat.
I think that is a clever idea.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 01-16-2015, 12:31 PM   #3
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Found it. Interesting idea!
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
6 gal water heater with heat exchanger? Gregsch Classic Motorhomes 24 12-05-2014 12:48 PM
'73 International with Hydroflame furnace with bad heat exchanger 73Argosy Furnaces, Heaters, Fireplaces & Air Conditioning 4 05-31-2011 02:03 PM
Rear heat exchanger water hose bypass ducatist2 Land Yacht/Legacy Motorhomes 5 03-24-2011 08:35 AM
Heater exhaust heat exchanger david686 Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-17-2010 07:58 AM
Heat exchanger for moisture control? SilvrSausage Roof Vents, Skylights & Fans 3 10-13-2007 01:00 PM
