Old 03-08-2011, 11:18 AM   #15
safari62's Avatar
1962 22' Safari
1957 22' Custom
Vacationland , Maine
Images: 43
Originally Posted by robwok View Post
Colin:
I love the help, but you have to realize, not all of us are sailor/racecarmechanic/fullmonterestorer/whoknowswhatelse guys like Colin Hyde. I don't really relish the idea of getting up on a frosty morning and finding I have no hot water and spending the morning out at the side of my vehicle trying to get the hot water tank working before my wife and kids get up.
robwok
I see you have picked up on the fact that our VAP STAR and all around great guy Colin Hyde is a man of many skills and experiences. His comfort/pain threshold may be much different then many of us that have yet to experience living in the tundra (Canada) and building experimental snow machines and ice racing in his spare time.
I believe he also travelled through many third world counties by yak (or camel) when the back of a stake body truck was not available.
I also think Colin was charmed enough to find on of those vintage trailers of some legend that was still in working condition. And if it was not....he probably can build a new part or invent a new way to fix it. And has.
I would like to have a true vintage trailer with all original equipment. As we all know the new replacement units ain't built the way they use to be.
But there is much peace of mind that can be had by going through your trailer and replacing and rebuilding everything that must be done before heading out on the road to a destination where you hope to do everything BUT work on the trailer.
I think you mentioned the trailer is it great condition....except for, well, all those things that must be repaired. Welcome to vintage trailer world. Fix it now or fix it later. At home on your terms or at a campground, or worst, on the side of the road.
So the moral of the story is: the trailer may be it great condition visually, but all the systems are suspect and need to be checked/repaired/updated or restored. Replacing the water and furnace? Sounds like a good time to renew the plumbing, gas lines, regulators now. It is never going to be easier then now.
But...I just added another year onto the completion date. But it is all part of the fun and starting on this project MAY keep you from buying another trailer in the mean time. Just trying to help!
Unfortunatley when you are finished Colin will still walk by your trailer at a future rally one day, and from thirty paces away spot the WRONG screw being used in one of your taillights! The shame with subside and life goes on.
Gary
safari62 is offline   Reply With Quote
Old 03-08-2011, 11:22 AM   #16
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Originally Posted by FreshAir View Post
Here is the pictorial - tutorial thread of my Bowen removal.
http://www.airforums.com/forums/f445...-in-36653.html
Neil
Neil:
That's extremely helpful. I'm concerned because it looks like mine is similar to the other one I saw on your post - the tank seems to be about an inch higher than the opening in the outside skin. I believe I have to take off the 4 screws on each side of the shroud, then possibly lift out the water heater from inside the closet.
robwok is offline   Reply With Quote
Old 03-16-2011, 08:38 AM   #17
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Originally Posted by vswingfield View Post
If you remove the outer trim and mounting parts highlighted in red in the photo, the hole is much larger. The water heater will then come out this hole. That's how I got mine out of my Trade Wind.
There will be some screws that you have to remove from inside the cabinets and you may have to move some things out of the way. You definitely will have to unhook the plumbing first before you can move it out the hole.
Looks like you've already remove the screws on the trim. I think you're on the right track. Colin is right, though, be sure and see if it is OK before you go to any more trouble.
Good luck!
Too far gone now. I dissasembled instead of taking a sawzall to everything, so the WH will probably be in great shape if someone wants it. Maybe I can sell it to Colin for several hundred since it'll last longer than a new one.
It seems that Steve from VTS was right about 64 being the year of experimentation. My WH was installed from both the inside, AND the outside.
In looking at the assembly, let me take you all back in time to how the factory did the 64 Overlander International WH in Ohio.
First, a small opening was cut in the side of the trailer. Then, this opening was reinforced from the inside with additional aluminum sheets to make the opening as small as possible.
Next, the outside flange was cut and formed, and a inner shroud was stapled to this flange. You can see that as the inside metal that touches up against the WH body. This shroud assembly was then backed with a black adhesive and the trim was filled with a significant amount of butyl tape. It was then screwed to the AS outside shell.
Next, a horizontal steel pipe was run through the top area of this shroud, and the propane was connected inside the trailer, and again from the inside of the shroud to the burner.
next, the tank was moved up to the shroud, and 4-5 screws attached the shroud to the tank from the inside of the AS.
Finally, a liberal amount of adhesive - like Vulkem was used for all of the seams to further glue the shroud to the WH.
The interior cabinets were then built around it all. Oh and the exhaust was screwed on.
So, how do you take it out?
Well, I popped the staples (not an easy thing) and pulled the outside trim off.
The best scenario is this: Burn the trailer and file an insurance claim.
Just kidding.
1. Remove the screws that are in the trailer that attach the shroud to the WH.
2. Unhook the propane supply line.
3. Then, go to the outside and cut the steel pipe that runs horizontally across. If you remove the fittings, you should be able to cut in the middle and pull the two pieces from the outside. If you don't take the ends off, you may be able to pull them through, but there are some fittings for the line to the burner that may be too hard to remove.
4. Once that line is cut, you should be able to remove the shroud. Due to the amount of glue and butyl tape, I suggest getting 2 plastic putty knives (they won't scratch the aluminum) and putting a wedge between them to slowly pry off the trim. You may be able to put a large screwdriver between them and slowly twist it to push the trim off the body of the AS.
5. Go under the body of the trailer and find the Pressure release valve drain pipe. This is a 1" pipe that hangs down through the belly pan. Use a pipe wrench to remove it from there instead of trying to do inside the AS. (unless you've removed all of the furniture, but I still think I had more room and leverage laying on the ground. The belly pan can be pushed up to get a grip on the pipe.
After that, clip or undo your water lines, and you may be able to lift it through the closet. I haven't gotten to that point yet. I finished up late last night, and just have the tank to remove, but I am afraid I may still need to remove the ABS drain lines to have enough room to get it out of there.
Feel free to post any additiona questions on this and I may be able to help. I removed mine in such a way, I could almost put it back in. Let me know if you need the old burner for parts too.
Old 03-17-2011, 07:32 AM   #18
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
On a side note, I was very careful in taking the burner assembly apart last night. I did have to cut the flue. I took the screws out, and tried knocking it side to side with 2x4 to keep from damaging it, but no such luck.
If you need a flue, thermostat, or any of the lines between them, let me know. Colin Hyde gets first pick though.
Old 03-17-2011, 08:35 AM   #19
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
My 1958 Bowen worked for the first months that I had my rig, then it burst. Water everywhere. I replaced it with a 6 gallon manual light Suburban, so I could reuse the old Bowen exterior venting -- much nicer than the new hatch covers. There is a tutorial here in the forum that I followed for the vent mod.
The Suburban gets hot FAST and recovers well. I keep it on the lowest setting and haven't run it dry (cold) yet.
"Pulling" the old tank out (from the outside) required getting inside and pushing with my feet, back braced against opposite cabinets.
-Michael
TAC CA-12
"All things in moderation, including moderation"
- Mark Twain
bevman is offline   Reply With Quote
Old 03-17-2011, 11:44 AM   #20
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
It's guaranteed that I can't pull it from the outside without cutting a larger hole. I have measured everything and it just is not going to happen.
Old 03-17-2011, 05:41 PM   #21
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Sure Rob, I'd love the remains of your heater. It'll keep mine going for another 52 years hopefully
Colin
Colin H is offline   Reply With Quote
cabinet, removal, water heater
