Old 12-05-2009, 05:53 PM   #1
dsrtgrls's Avatar
2010 19' Flying Cloud
Clarkdale , Arizona
how to remove moen undersink water filter on 2010 bambi
if anybody nows how or could point me to the instructions on how to do it. it would be appreciated because it is not just unscrewing like i thought it would/should and i have no literature on the moen faucets or filter. thanks.
dsrtgrls is offline   Reply With Quote
Old 12-05-2009, 06:02 PM   #2
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Mine twists off though it can be stubborn. I can't remember if you have to raise or lower it over a tab to remove it. Last time I took it off it was a bit of a struggle, but I finally got it.
There should be instructions with the package of stuff the dealer gives you, but they do leave stuff out.
Gene
Old 12-05-2009, 07:51 PM   #3
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
This is not much help, but the filter in my 2010 is not the same as the one in the manual. I got my off without much trouble though. Unfortunately the trailer is in storage so I can't look. I believe I found the manual for the filter on Moen's web site. I will look through the manuals and see if I find it.
Regards.Ken
Old 12-05-2009, 08:00 PM   #4
Ag&Au's Avatar
I found the manual. It is for the Moen ChoiceFlo 9500/9600.
You unscrew it normally, but then you need to tug down pretty hard as there is an o-ring that must be overcome. My wife got the manuals for the bathroom and kitchen faucets and the filter by calling Moen customer service. They also sent a free repair kit for our bathroom faucet, because it was leaking. Good luck with it.
Ken
Old 12-05-2009, 08:45 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Should turn clockwise to remove it. When you reinstall it coat the O rings with silicone plumbers grease to make removal easier the next time.
Don't use Vaseline as a replacement....
Old 12-06-2009, 07:38 AM   #6
dsrtgrls's Avatar
Clarkdale , Arizona
thank you all. i did contact moen website and got the info. and got that bugger off in the nick of time. i will remember the silicone plumbers grease.
1969 Overlander Int'l water question - filter on outside water hook up? edmund015 Water Heaters, Filters & Pumps 3 08-20-2009 10:30 PM
hello - 2010 bambi dsrtgrls Member Introductions 15 08-13-2009 07:30 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
2006 Classic Moen Faucet Filter Pappy Water Heaters, Filters & Pumps 18 10-02-2006 10:54 AM
Moen 601 water filter jcanavera Water Heaters, Filters & Pumps 3 04-04-2006 09:29 PM
