Old 02-27-2006, 01:55 PM   #1
1966 17' Caravel
Seattle , Washington
Send a message via AIM to kitchenclose
How to remove a hot water tank?
Hi and Thanks for reading.
I have a 1966 Caravel 17 footer which has wood rot beneath the hot water tank.
I would like to know how to remove the hot water tank. Any suggestions would be appreciated.
PS - I have searched this forum but couldn't find the answer.
Karen
kitchenclosed@hotmail.com
kitchenclose is offline   Reply With Quote
Old 02-27-2006, 02:15 PM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Unhook all waterlines. Unhook LP line. Remove all fasteners along outer edge of tank, on outside of the coach. Pull tank assembly out of coach. It will be a tight fit, if you cannot get it out, check inside to make sure plumbing is not caught on any part of the tank. It is a tough pull to get it out. I am assuming you have an older water heater that does not have any electrical connections. If not make sure they are disconnected before trying to pull tank out.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-27-2006, 02:24 PM   #3
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
Assuming you have an Atwood or Suburban water heater, you can pull it out through the outside access. I know I did a '64 Bambi with the older round water heater and it has to go out via the door (and a lot of dissassembled cabinetry).
Zep@Charmedquark.net
Old 02-27-2006, 04:06 PM   #4
Retired.
. , At Large
There MAY be a single wood screw holding the tank on the inside floor on the extreme inboard bottom edge of the water heater. It is attached to a small L shaped bracket that is bolted to the housing of the water heater. Our Argosy had the screw, the Overlander does not.
Old 02-27-2006, 06:40 PM   #5
Darol Ingalls's Avatar
There may be a couple pieces of interior skin that you can remove by drilling out the pop rivits which would make getting the water tank out easier. If it's one of the 10 gallon versions, you will have to turn it a little sideways to get it out. Since you found the floor rot, think about installing your new w/h on a raised platform to allow air to circulate under it. The exterior flange does most of the "holding" of the unit in place, but make sure you build the platform sturdy enough to hold 6 gallons of water weight.
Darol Ingalls is offline   Reply With Quote
Old 02-27-2006, 07:49 PM   #6
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Your experience will certainly be different from ours but you can look over what we did. Hopefully it will help you. It isn't hard..
http://overlander.archnevada.com/index.php?waterheater
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Inside hot water heater cover davidz71 Water Heaters, Filters & Pumps 12 03-24-2008 08:11 PM
Safari owners Jerry Sulkin 1969 - 1973 Safari 30 02-20-2006 07:07 PM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
