Old 09-22-2010, 08:57 AM   #15
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by wasagachris View Post
I was hoping Lew would chime in on this. I knew he would have the answer.
Lew do they also incorporate a check valve for winterizing?
Do you need this valve? Couldn't you just install one way (check) valve instead?
Atwood's W/H just slip right in and don't require any mods to skins.
What has to be done to service these valves?
YMMV? Don't know that abreviation yet.
NO. You need to put in a winterizing bypass kit which you can get from any well stocked RV supply shop. The check valve is usually added to the hot water output side to prevent cold water from returning into the tank when the water system is pressurized. It wouldn't help in winterizing.
Servicing the valves entails removing the valve from the output side of the heater and soaking it in warm vinegar to dissolve any hardened mineral solids that mat have formed within the valve. I have tried this a few times with unsatisfactory results! I am NOT a fan of these 'high capacity' water heaters for that reason.
Minno, you theoretically could remove this mixing valve, but that would give you 140* output water at the faucet which WILL BURN YOU! as the thermostats in this unit are 20*F hotter than normal units. Atwood has added this valve in the attempt increase the water capacity of these units and limit their legal liability. JUST GET A NORMAL ATWOOD UNIT, NOT THE HIGH CAPACITY ONE.
And finally, YMMV = 'your mileage may vary'
Old 09-22-2010, 10:02 AM   #16
Splitrock's Avatar
Sioux Falls , South Dakota
Good information Lew,
Thanks for your comments. I think you just helped me avoid another mistake.
Does Atwood make a heater with an adjustable water temperature dial similar to the one I just removed? Or:
Which model 6 gallon gas/110 volt electric Atwood would you suggest?
Gary
Old 09-22-2010, 09:38 PM   #17
lewster's Avatar
Gary
I'm not sure of the model number but they have a dual LP/120VAC electric model that has direct spark ignition (DSI). This is the one that you want, as it is fully automatic on the LP side and you can run it on BOTH LP and 120VAC if you like for faster recovery.
Old 09-22-2010, 10:18 PM   #18
Splitrock's Avatar
Okay, so if it says High Capacity, I don't want it.
Thanks for your help.
Gary
Old 09-23-2010, 06:30 AM   #19
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Yup - good information Lewster. Thanks!
Chris
How to make pic smaller Angel73 Forum Admin, News and Member Account Info 4 09-21-2010 11:20 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Tips for Smaller Truck/Smaller Trailer Combinations SilverCabin Tow Vehicles 19 01-10-2007 06:38 PM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
