Old 10-22-2014, 12:45 AM   #1
1968 30' Sovereign
Kinglake , Victoria
How to get the water heater out?
Hi there,
I'm still a very new owner and am just stripping all interior out at this stage. Got most out, but the hot water heater in my 1968 Sovereign is very well fixed into the wall. They used staples that are very tough.
Anyone got some tips?
thanks!
Germanaussie
Germanaussie is offline   Reply With Quote
Old 10-22-2014, 01:46 AM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Staples? That sounds very odd. Can you post photos?
Zep
Old 10-22-2014, 07:25 AM   #3
indy's Avatar
1962 22' Safari
kansas city , Missouri
Images: 22
Ours was built in after it was set. Inter skins installed around the beast.
A ripocating saw was our answer to the problem.
indy is offline   Reply With Quote
Old 10-22-2014, 11:50 PM   #4
1968 30' Sovereign
Kinglake , Victoria
I will try and get some pics, if I can get my camera to work.
It's going to be a tough one as there is not much space for sawing...
Will report back.
Regards,
Fenja
Old 10-23-2014, 12:39 PM   #5
indy's Avatar
1962 22' Safari
Images: 22
I understand what you mean , the factory dented in the cornner of the old tank to fit a vent pipe in,
in the pic I cut and removed temporary the pipe to make for the heater room to go out the side. The iner skin was cut with snips called offset I can get a pic if needed.
Old 10-23-2014, 12:49 PM   #6
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
several posts on water heater. Mine came out through the ouside, but it wasn't easy. I vaguely recall some hidden fasteners that I had to feel more than see. Pulled mine out from the outside.
robwok is offline   Reply With Quote
Old 10-23-2014, 12:52 PM   #7
1974 Argosy 20
Kooskia , Idaho
I have replaced several over the years and have found that once the screws are all removed from the external flange and the putty tape cut a push from the inside removed every one. The fit is close though, and the putty tape is not willing to give up easily, but each of mine have come out with no sawing.
Old 10-24-2014, 01:14 AM   #8
1968 30' Sovereign
Kinglake , Victoria
Thanks, that is really helpful. I will try some different tools for the fasteners and see how I go. I didn't think mine would fit through the vent door but not a problem as my AS is totally stripped now.
Regards,
Germanaussie
Where can I get a water heater controller willerjim Water Heaters, Filters & Pumps 1 09-18-2009 02:44 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Where can I get a stainless water heater door? Silver Threads Water Heaters, Filters & Pumps 4 06-23-2007 05:51 AM
How do I get this water heater out 63air Water Heaters, Filters & Pumps 2 08-20-2005 04:36 PM
It take 5 minutes to get the gas flowing to my fridge, water heater, etc. TBKP's Overlander LP Gas, Piping, Tanks & Regulators 8 04-15-2003 10:00 PM
