Old 06-30-2013, 07:38 PM   #1
2010 19' Flying Cloud
Hailey , Idaho
How to fix my mistake?
Sooo... we've had pretty good luck with our Atwood so far (G6A-8E, had it two years with a lot of fulltiming ( about 13 months and counting all told.)) Can't believe this hasn't happened before today but we ran out of water (fresh water) while the water heater was engaged. Turned off the water pump and then refilled the tanks. Tried taking a shower and realized that I hadn't turned water pump back on. Did and...no hot water. Now the hot water pump won't light. Turn it on; no light, no attempt to ignite, nada.
I checked the board and everything is connected and breaker and thermal shut off are continuous. Is it stuck in lock out? Haven't blown it out or anything yet (it's going to be a field repair, we're here for another week with the closest RV shop of any sort 25 miles away)
Thoughts or suggestions? It would seem this would happen sometimes but I didn't see anything on the boards Fortunately, it's hot enough right now I don't mind the cool showers but my wife cried when it was her turn!
Thanks in advance and happy 4th everyone!
guntertl is offline   Reply With Quote
Old 06-30-2013, 07:55 PM   #2
1971 31' Sovereign
fort myers , Florida
shut down all electric service for a few minutes. Power up,then turn on the water pump,and then the heater. If this does not work,use a continuity tester to test the water heater element.You will also want to check the low voltage fuses by the converter.
swampthang7 is offline   Reply With Quote
Old 06-30-2013, 07:58 PM   #3
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Wow. Interesting. When you turned the water pump on after filling the tanks, it should have filled the water heater, which of course should have fixed the low water level safety. I don't have an answer, but maybe this bump will put it in front of someone who does.
robert claus is offline   Reply With Quote
Old 06-30-2013, 08:31 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Do you get a red light when first turn on the gas WH switch?
If you do but no hot water, remove and clean the igniter probe
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-30-2013, 09:33 PM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I recently started getting smuts from my water heater - and not liking to mess with propane appliances, snagged the local "mobile RV repair" guy when he was visiting our campsite.
He did a thorough cleaning - which was embarrassing - because it looked like something you'd see a chimney sweep clean out, then he actually adjusted the hinges on the bottom of the DOOR to stand out a bit from the side of the Airstream and let a bit more air into the ignition chamber. Apparently most of the soot buildup was from burning with too little oxygen and again apparently Atwood has known this is a problem generally.
Anyway if you fulltime and leave the water heater running most of the time you need to have it serviced or service it yourself once a year; mine had been closer to two years. In your case I agree with turn everything off for a minute or two and then reset. Of course .... you have checked to make sure you didn't run out of propane, right? (I ALWAYS seem to run out at 3:00 AM).
Paula
Old 07-02-2013, 02:47 PM   #6
Hailey , Idaho
Thanks all for the suggestions.
I've checked all fuses (converter as well) and nothing blown. Disconnecting all power (battery and shore) for 5 minutes did nothing for the problem; still no light or attempt at ignition. I'll have to pick up a continuity tester in town as I don't (but should) have one with me. Propanes not the issue. I don't usually leave the water heater on as we only use it for showers. This was a case of bad timing (water running out while it was on.) I saw some talk about replacing some solenoids (right term?) as opposed to the whole circuit board which costs $100. Looks like I'll be investigating that option now.
Thanks again and enjoy the holiday!
Old 07-02-2013, 03:15 PM   #7
1986 31' Sovereign
Miami , Florida
With the switch "on" and while studiously avoiding the high tension wire that leads from the board to the igniter, gently wiggle all the other wires.
Worth a shot and usually does the trick.
Mike
Old 07-02-2013, 03:18 PM   #8
Okiestreamer's Avatar
1999 25' Safari
Adair , Oklahoma
Have you called Atwood to see if they can help? 574 264-2131 Might be worth a shot.
Dave
Okiestreamer is offline   Reply With Quote
Old 07-02-2013, 05:37 PM   #9
Hailey , Idaho
No I haven't. Good idea, Duh!
Old 07-02-2013, 05:48 PM   #10
Hailey , Idaho
Mike
Ummmm, is the high tension wire the one that connects to the thermostat? Separate from the wiring harness? thanks I'll try it when it stops raining!
Old 07-02-2013, 06:16 PM   #11
1986 31' Sovereign
Miami , Florida
The high tension lead is thicker than the others and leads from the control board down to the igniter.
Mike
Old 07-02-2013, 07:53 PM   #12
Hailey , Idaho
Yeah, tried your suggestion and nothing. Calling Atwood tomorrow but likely will just buy a circuit board and install myself. Seems pretty straightforward. Thanks for the suggestion.
Old 07-02-2013, 08:11 PM   #13
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Good luck, sorry for ur trouble, I am of no help, but had to say....wow you full-time in a 19' Bambi? I am impressed.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 07-03-2013, 07:32 AM   #14
Hailey , Idaho
Yeah, me, my wife and 160lbs of dog! Get's pretty tight on rainy days. Needless to say I spend a lot of time outside!
