Old 06-10-2010, 09:54 PM   #15
2005 22' Safari
Gresham , Oregon
Our first few trips out we turned on the heater and left it on until we left. But we have found since it is only two of us, we turn it on shortly before we want showers.We also do navy showers. Doesn't take very long for the water to heat. Plus we are camping and what is the hurry for a shower? We have turned to a lot of paper plates, cups ect - therefore generally we don't have a lot of dishes. I usually just set the dishes needing to be washed in a plastic tub that fits in the sink, and wash dishes at the end of the day. Works for us.
sempi2 is offline   Reply With Quote
Old 06-10-2010, 10:09 PM   #16
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
It depends which water heater you have, but it doesn't seem to me any water heater would run constantly. Eventually the water would be boiling. There should be a thermostat to turn the flame (or electricity) off when the water is up to temp. Maybe your thermostat is defective, or the flame is not properly adjusted to heat the water quickly. The burner may need cleaning. I'm sure there could other things to check too.
I find the water heater we have heats water very fast. We turn it off when not using it to heat water for a shower or washing dishes. The tank is very well insulated and water stays hot for many hours.
Even in Winnipeg the water temp should not be so cold at this time of year to cause the water heater to run so long.
Gene
Old 06-10-2010, 10:42 PM   #17
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
In our Excella, we turn the water heater on when we get up in the morning, turn it off after breakfast dishes. On again when we start dinner, off again at bed time.
Our Caravel has a Precision Temp RV 500. Works on demand and only heats water needed. Doesn't use much gas at all, but the unit, installed by the PO, is big bucks.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Water dripping from heat pump Loren Furnaces, Heaters, Fireplaces & Air Conditioning 5 10-27-2015 10:02 PM
Help with 85 Heat and Water Heater NashBuff Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-06-2009 09:46 AM
Water heater won't heat John Greenlee Water Heaters, Filters & Pumps 8 09-28-2005 06:14 PM
Hot water radiant heat? malconium Furnaces, Heaters, Fireplaces & Air Conditioning 32 07-07-2004 02:27 PM
Water Heater does not heat Alan and Mardel Water Heaters, Filters & Pumps 6 12-13-2003 09:06 PM
