Old 06-23-2014, 10:25 AM   #1
2011 30' Flying Cloud
Fort Worth , Texas
Hot Water with propane only
I have no hot water when my hot water heater is in the electric use position. But when it is in the propane position, it heats up just fine. My wife tells me that earlier she was able to smell some sort of electrical smell. Her sense of smell is much more discriminating that mine so I believe her, but was unable to locate where that smell might be coming from. Any thoughts? Can the water heater be unable to heat water with electricity but still function with propane? The breakers are all on, but is there any breaker or switch elsewhere - perhaps near, or on, the water heater? Or do I have to replace the whole thing?
mosbymorgan is offline   Reply With Quote
Old 06-23-2014, 10:30 AM   #2
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
You can heat the water by just using propane. May be others can answer the electrical issue.
urnmor is offline   Reply With Quote
Old 03-12-2015, 12:00 AM   #3
cptfish's Avatar
2014 27' FB International
salem , Oregon
I have the same problem! Did you find a fix for the electric heating of your hot water instead of the propane?
cptfish is offline   Reply With Quote
Old 03-12-2015, 12:57 AM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Check the fuses
Then replace the element itself - they DO burn out just like incandescent bulbs.
Even with a zinc anode they will corrode eventually.
Paula
Old 03-12-2015, 04:11 AM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
The smell might be coming from the electric thermostat. I have seen them burn on more than a few friends trailers. I have been lucky thus far!
Old 03-12-2015, 06:21 AM   #6
macofpei's Avatar
2003 30' Classic
Stratford , Prince Edward Island
Send a message via Yahoo to macofpei Send a message via Skype™ to macofpei
I had this happened to me. There is a switch on the wall but also at the water heater. The wiring behind the grey box cover that holds the switch to the water heater is where the wire burnt off The switch was also burnt.. I had to replace the switch ( found at a large box store for about $5.00 Canadian), reconnected the wires and -- presto-- works great.
Just be sure that the 120 volt is shut off for your protection when working on these wires.
Mac from PEI
Canada
WBCCI #4782
"Southern Belle"
'03 Classic 30'
'10 Toyota CrewMax
macofpei is offline   Reply With Quote
Old 03-12-2015, 07:12 AM   #7
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
water heater electric element will burn out quickly if not fully immersed. if you are using tank water and run out of water, turn off heater immediately and dont turn back on until you are sure theres no air in water heater tank.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 03-16-2015, 11:29 AM   #8
cptfish's Avatar
salem , Oregon
On out way to get water electric switch checked in LA and install of new circuit board and motor provided by ZipDee. Seems like after this our trailer will be like it should have been delivered when it was new 14 mths ago. ZipDee has been working hard to get this circuit board right (our third one and fourth motor).
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 02:08 AM
Hot Water not hot enough??!! maryehill Water Heaters, Filters & Pumps 15 04-24-2012 01:58 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 10:03 PM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 07:58 PM
Only hot water coming out of shower. TBKP's Overlander Plumbing - Systems & Fixtures 6 06-21-2003 03:41 PM
