Old 04-09-2017, 01:17 PM   #1
1975 Argosy 22
Eugene , Oregon
Question hot water tank flush
Can I use a pressure washer on the lowest setting to flush out the debris in my Suburban hot water tank?
mrdfred is offline   Reply With Quote
Old 04-09-2017, 01:39 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Not sure that would be a good idea. Never did or hear of anyone else. I would be afraid the pressure washer would dislodge debris in flakes and unless you flush it all out might travel and cause other plumbing problems. I am just guessing. Debris is probably a lime accumulation. I would fill the hot water tank with a strong vinegar solution which would dissolve the lime. A little bit of lime is normal.
Old 04-09-2017, 01:45 PM   #3
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
I'll be curious to see if somebody else on Air Forums has used a pressure washer to clean their water heater.
I don't know if it can be done without damaging the tank. Consider contacting Suburban and ask their advice. I'm guessing there are few if any people that use a pressure washer to clean out their water heater.
Why do you need to use a pressure washer? Have you tried a simpler, low-pressure approach? If so, did that method not work to your satisfaction? Is there actually a build-up in your tank that needs to be flushed to the degree that a pressure washer is necessary?
Consider inserting a small inspection camera into the tank to see if you have significant build-up before you accidentally blow out the tank with high pressure spray. Simple inspection cameras are available at Harbor Freight and similar places for under $50 - lots less expensive than the possibility of ruining a water heater.
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 04-09-2017, 02:02 PM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
There is also a wand type device that attaches to a garden hose. I think Camco makes it.
Old 04-09-2017, 02:52 PM   #5
2007 27' Classic FB
Ridgefield , Washington
Images: 8
We use the Camco. five or six dollars. Plenty of power to do the job.
John & Lisa
Woosch is offline   Reply With Quote
Old 04-09-2017, 03:21 PM   #6
2014 23' FB Flying Cloud
Park City , Utah
https://www.amazon.com/Camco-11691-W...s=rv+tank+wand
pcskier is offline   Reply With Quote
Old 04-09-2017, 03:31 PM   #7
1975 Argosy 22
Eugene , Oregon
I like the idea of a vinegar solution. How do I get the vinegar solution into the tank?
Old 04-10-2017, 09:24 AM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
Unscrew the pressure relief valve at the top and add the vinegar solution. Let it sit for a few hours or overnight, then drain. Then fill and rinse a few times until no more crud comes out of the drain. You will have vinegar smell and taste to your hot water for a cycle or 2.
Old 04-10-2017, 11:18 AM   #9
Mollysdad's Avatar
I'd say, NO.
But I found a great video on rinsing out the water heater of scale and deposits.
Old 04-11-2017, 05:22 PM   #10
1975 Argosy 22
Eugene , Oregon
I watched the video on youtube, thanks! Loaded in 3 gal of vinegar and topped it up, turned on the heater and let it sit overnight. I flushed it in the morning and am now ready for the summer. Thanks a bunch!
Old 09-12-2017, 12:43 PM   #11
2007 23' Safari SE
Annandale , New Jersey
Tried unscrewing the PRV and doesn't seem to budge. Would say I didn't put all my strength into it, but felt I was getting close to something else giving, or rolling the trailer down the driveway.....
For just a split second, considered liquid wrench, but realized this was a potable water tank.
Thoughts?
Fred L is offline   Reply With Quote
Old 09-12-2017, 06:30 PM   #12
1979 23' Safari
Wayland , New York
Thoughts?
Was it hot or cold when you did it. If cold try heating the tank back up with water inside it then just try to get it to break free. Then turn it off and run hot water faucet to get the hot water out of there. Then remove the rest of the way.
I made a short hose with a valve I could screw into the drain before filling with vinegar. Then after the vinegar soak I could get some good flushes under pressure, starting and stopping flow to stir up sediment.
Old 09-13-2017, 09:19 AM   #13
2007 23' Safari SE
The trailer is new to me and PO said they hadn't run the WH since they bought it as stayed at full hookup campgrounds (Also never used the range or oven from the looks of it).
So working on getting the HWH to run and have ordered parts, but also wanted to flush the tank before running water through it.
Not sure I follow your second thought, but are you saying to hook up a short length of hose to the male end of the PRV, open the valve and pour vinegar in the other end of the hose ?
Old 09-13-2017, 09:23 AM   #14
dmbecke's Avatar
Des Peres , Missouri
How often would one perform this cleaning
I have a 2014
dmbecke is offline   Reply With Quote
Black Water Tank Flush: Park Water Pressure cbrittan Waste Systems, Tanks & Totes 2 08-01-2016 06:32 PM
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 10:45 AM
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 02:08 AM
Help! My '63 overlander need plumbing, hot water tank, and water supply tank! aprilr 1960 - 1964 Overlander 9 11-30-2011 09:52 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 10:03 PM
