Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 03-03-2007, 05:58 PM   #1
FreshAir
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
Hot water tank drain.
I had given up months ago trying to locate a drain for my Bowen HW tank in my '66 Tradewind. I am now replacing my black tank and replacing the floor under the rear bath toilet from underneath. After removing the old floor up to the HW tank I found the tank drain in the most rediculous place. It is on the back of the tank (inside to the trailer) with absolutelty no access unless you cut out the floor or cut into the bathroom cabinet,,,,then there is no exit for the water to drain. Now some off you must have the same wierd configuration. How do you drain the tank? I am thinking with the floor out I may attach a drain line and run it to underneath the trailer and a valve. Is this a solution? What have you done?
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
Lake San Antonio, 10/07
'Cover Photo'
1966 Trade Wind
455 cid
FreshAir is online now   Reply With Quote
Old 03-03-2007, 07:53 PM   #2
crestonrv
crestonrv's Avatar
Profile:  1948 16' Wee Wind
1981 31' Excella Limited
2007 19' Bambi
crossville , Tennessee
pull it toss it and put in modern equip. tank is prob not long for this world anyway.( rot through at bottom ) food for thought before you modify coach for an obsolete appl. note the older you go the weirder it gets!!! new atwood about 250.00 if more e me I'll get u 1 piloot mod g6p atwood. save old door can be made to work keep cool appearance.
crestonrv is offline   Reply With Quote
What Grey Water Tank?? niftypkg Waste Systems, Tanks & Totes 6 09-04-2002 07:12 PM
Hot water Heater DClark Water Heaters, Filters & Pumps 11 08-26-2002 06:04 PM
Faulty Emerson RV E-330-5 Hot Water Dispenser winner Water Heaters, Filters & Pumps 4 08-02-2002 02:07 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
Leak in hot water heater tank Rog0525 Water Heaters, Filters & Pumps 8 06-10-2002 02:10 PM
