Old 11-23-2006, 02:58 PM   #1
1969 27' Overlander
Auburn , Washington
hot water tank and bathtub
What holds the hot water tank to the trailer besides the screws around the outside frame? And...how do you disconnect the drain on tub to remove tub?THANKS for any help!
Its a 69' overlander
mark silberl is offline   Reply With Quote
Old 11-23-2006, 03:24 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Inside there may be a bracket holding it in.
The Tub Drain Un-screws, I heated mine up with a hair dryer to get the plumbers putty to loosen up.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 11-23-2006, 06:10 PM   #3
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Exclamation A word of warning....
If you are unscrewing the tub drain to take it out, be careful with the plumbing directly under the drain that sits in the little plastic bucket thing. That one piece is very hard to replace with anything that is currently available. Ours had a crack in it, and we spent much time and money looking for something that would "work". Short story.... plumbing speciality place in Kansas City had to special order it.
Just be careful ---- "if it's not broke, don't fix it"
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 11-23-2006, 07:16 PM   #4
1969 27' Overlander
Auburn , Washington
Got er done
Thanks for the advice- I ended up cutting the drain pipe near the wall and got the hot water heater out too.
Starting up trailer questions pompaneaux Electrical - Systems, Generators, Batteries & Solar 24 06-10-2010 12:08 PM
Grey water wagon storage? Jabba Our Community 16 04-26-2003 04:47 PM
Bathtub drain davidz71 Sinks, Showers & Toilets 8 02-23-2003 12:14 PM
1973 23' LandYacht Safari Purchase / Winterize?? Sampsel Winterizing, Storage, Carports & Covers 5 11-07-2002 08:12 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
