Old 07-21-2016, 01:50 PM   #1
2007 27' Classic FB
Tupper Lake , New York
Angry Hot water tank
The propane switch works fine, but elect switch will not turn the heater, what's up. how to fix. Changed the 2amp fuse & still the same.
Diesel75 is offline   Reply With Quote
Old 07-22-2016, 02:32 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Probably a burned out element from someone running it while the water heater was empty. Check with a meter, or just replace, they're cheap but it can be difficult to get the old one off.
Old 07-22-2016, 03:06 PM   #3
Long Island , New York
Jammer is probably right IMO, if you are sure that you have proper 120 volts to the water heater, which you can check via the exterior access door. Make sure the circuit breaker is not thrown.
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 10:45 AM
being frugal with hot water ó best ways to manage hot water cost lbdesign Full-Timing, Winter Living & Workamping 23 12-17-2015 10:14 AM
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 02:08 AM
Help! My '63 overlander need plumbing, hot water tank, and water supply tank! aprilr 1960 - 1964 Overlander 9 11-30-2011 09:52 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 10:03 PM
