Old 06-08-2019, 01:03 PM   #1
1972 Argosy 20
Anchorage , Alaska
Hot Water Relief Valve
I have a 1972 Argosy Trailer. I just bought it and when testing all of the components I found that the relief valve in the hot water heater leaks when pressure build in the tank. I am able to find new relief valves but they are all 150psi and the one that I took out of the hot water heater is 125psi. Has anyone had luck finding a relief valve that is 125psi? Or has anyone changed these out using the 150psi one without any issues? 25psi in that tank is a lot of extra pressure.
BriAK is offline   Reply With Quote
Old 06-08-2019, 02:24 PM   #2
Kevin245's Avatar
I bought one a few years ago from McMaster-Carr. It’s called a T&P Valve.
William C. Swinney
Old 06-08-2019, 02:53 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
How bad is it leaking?
Have you tried snapping it open and closed?
How old is the water heater?
Old 06-08-2019, 03:07 PM   #4
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
https://www.homedepot.com/p/Cash-Acm...0150/203164746
This one should work fine.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 06-08-2019, 06:34 PM   #5
1972 Argosy 20
Anchorage , Alaska
So you think using the 150psi instead of the 125psi that is in there is ok?
Old 06-08-2019, 06:35 PM   #6
1972 Argosy 20
Anchorage , Alaska
I did try and it just caused the slow flow to become a fast flow.
Old 06-08-2019, 08:47 PM   #7
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
These are Atwood/Dometic, made for their water heaters.
What size pipe thread. Older WH have 1/2". Newer have 3/4".
Could be this>
https://www.amazon.com/Atwood-91604-.../dp/B000N9PRKG
or
Could be this>
https://www.amazon.com/Atwood-90028-.../dp/B004QN14UW
Alan
Old 06-08-2019, 09:05 PM   #8
A W Warn's Avatar
2000 25' Safari
I checked the specs on both of the above valves. They are 150 psi.
Alan
Old 06-08-2019, 09:45 PM   #9
2007 22' International CCD
Main reason the valve is Installed is for over temperature issues. It’s not going to pop on over pressure. The PEX or the input regulator will most likely blow first.
Old 06-16-2019, 05:11 PM   #10
2017 25' Flying Cloud
Woodway , Texas
The T&P valve in our 2017 weeped from the start. We resolved it by replacing with one from Home Depot for less than $20 vs the poor-quality, OEM one. rmkrum is correct--even if your water heater could achieve 150+ PSI, the resulting pressure would blow out a PEX seal, pressure regulator or even the braided supply hose before the tank itself could rupture. Happy travels!
emelaich01 is offline   Reply With Quote
Old 07-06-2019, 09:54 AM   #11
Cispook's Avatar
2017 27' Flying Cloud
Greer , South Carolina
Did your Home Depot replacement model have the probe?
Cispook is offline   Reply With Quote
Spewing water from relief valve on hot water badkat Plumbing - Systems & Fixtures 13 03-19-2014 09:36 AM
Relief valve.... not hot water heater Enid Plumbing - Systems & Fixtures 17 08-30-2012 02:44 PM
Water heater spitting from relief valve polarlyse Water Heaters, Filters & Pumps 5 06-26-2009 08:30 AM
Water heater pressure relief valve woliners Water Heaters, Filters & Pumps 6 07-10-2008 07:12 AM
water heater pressure relief valve wayne.yl Water Heaters, Filters & Pumps 12 04-21-2007 05:54 AM
