Old 10-24-2014, 08:27 PM   #1
jimbo1087's Avatar
2012 30' Flying Cloud
Box Elder , USA
Hot Water Pressure Low
In our 2012 Flying Cloud (30 ft) we are experiencing low hot water pressure. The cold water pressure is very good. I flushed the tank and there was some sediment in the tank. Temp is warm when using the electrical switch and hot using propane.
I'm thinking that the thermal sensors are going out, but I thinking that shouldn't effect the pressure.
Any thoughts would be helpful. Thanks in advance for any suggestions.
2012 Flying Cloud 30'
2016 GMC 2500 Duromax 6.6
jimbo1087 is offline   Reply With Quote
Old 10-25-2014, 08:27 AM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Can we assume the hot water pressure is low at both the galley and bath and shower faucets? And we assume the hot side water pressure is low even if the water heater is turned off.
So there must be a blockage in the hot water "main" line that exits the water heater and typically runs the length of the trailer. Some folks run this line in "red" PEX, and the cold lines in "blue" PEX like I did.
I'd first check the bypass valves to ensure the one on the hot line is fully open. I'd probably close it, and open it again with a hot faucet open as that might clear some debris. And I'd check the one on the cold water into the water heater for the same way for the same reason. Any restriction in these valves could cause low flow on the hot side.
David
Name:	1404 Plumbing Bypass Valves 1.jpg
Old 10-25-2014, 08:30 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
http://www.airforums.com/forums/f445/very-low-water-pressure-for-hot-water-from-pump-121902.html
Old 10-25-2014, 11:50 AM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks Mr Morgan, I did not know new style hot water heaters had a mixing valve on hot water coming out. As stated in your link, this a solution looking for a problem. I would not want one on my trailer.
David
Old 10-25-2014, 03:43 PM   #5
jimbo1087's Avatar
Box Elder , USA
dbj216;
Thanks for the picture (Worth a 1000 words). I was wondering how to run the lines. Hot water pressure is low in the bathroom, kitchen and shower. After reading all of the comments I'll be removing the valve.
Also a thanks to J. Morgan for the suggestion of removing the valve.
Old 10-25-2014, 04:31 PM   #6
Wayward's Avatar
Cary , North Carolina
I am not familiar with what Airstream has put in the newer models, but I have a mixing valve at home.
A mixing valve can serve a useful purpose by allowing a much higher hot water temperature than would normally be safe.
6 gal of 200 degree water goes a longer way than 6 gal of 120 degree water.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 10-25-2014, 06:47 PM   #7
jimbo1087's Avatar
Box Elder , USA
There have been several comments raising concerns about safety issues of water temps between 170 to 200. These are very validate concerns. Again I really appreciate all of the comments.
Old 10-25-2014, 08:46 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
In the old days it was possible to turn the water temps down. Maybe this cant be done with the newer heaters.
Old 10-25-2014, 09:06 PM   #9
lewster's Avatar
Naples, FL , Hood River, OR
Thermostats in the more recent RV water heaters made by Atwood and Suburban use fixed temperature thermostats available in either 130F or 140F settings. I have seen an aftermarket 'adjustable' replacement, but it is not Ul or CE approved and will void your warranty, not to mention putting your personal safety at risk.
Old 10-26-2014, 05:56 PM   #10
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Well regardless,,, if it was me,, when I would have gotten a price of two hundred bones for a valve that only lasted a few years I would pull it out.
That price is a rip off. As a mater of principle, the mixer would thereafter be on my shower valve and only on my shower valve.
Old 10-26-2014, 06:18 PM   #11
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Oh yes, most modern faucets have a mix device which also limits the temp giving some additional safety.
AtomicNo13 is online now   Reply With Quote
Old 10-27-2014, 05:11 AM   #12
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I recall from my factory days that I could place my hand on and hold a 120 degree temp item. I could touch, but didn't want to hold, a 140 degree item. 140 degrees hot was my upper limit. I believe factory safety regulations require personal protective equipment for temps above 120 degrees.
140 degree water is hot, and will scald the skin some. I think the water heater temps of 140 deg is safe.
David
Very low water pressure for hot water from pump barrettjl Water Heaters, Filters & Pumps 21 10-27-2014 07:41 AM
Hot water pressure low connorsa Full-Timing 4 09-11-2009 01:11 PM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Low hot water pressure??? FBC72 Water Heaters, Filters & Pumps 2 07-29-2007 10:49 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
