Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 01-17-2017, 07:52 AM   #1
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera , Texas
Hot Water Only, Then None
On a 2012 23D acquired last month.....affecting shower and both sinks, less so at kitchen. Water flow mix heats up as expected, then goes to hot only from both the hot and cold sides. And then the hot is totally gone, like I drained the tank, which isn't possible. Thoughts before I call a mobile repair, as we're traveling?
banderabob is offline   Reply With Quote
Old 01-17-2017, 08:59 AM   #2
Sag Harbor , New York
Possibly the mixing/tempering valve on the back of the water heater has gone bad? Maybe check your owner's manual to confirm you have one, and check its location. If accessible, you may be able to swap it out yourself IMO.
There is a recent thread on this:
http://www.airforums.com/forums/f445...er-161376.html
This sub-forum's list of topics contains other possible helpful threads:
http://www.airforums.com/forums/f445/
Good luck!
Peter
Old 01-18-2017, 02:47 PM   #3
banderabob's Avatar
2008 19' Bambi
Bandera , Texas
Me-thinks it is the mixing valve on the hot water heater, and we'll take care of it when we get home......spongies till then. Thx.
None Yet :: 1997 Airstream Legend Norman Rockwell SARGE/AF Airstream Registry Discussions 4 08-26-2021 08:37 AM
Spotty hot water to kitchen sink, none to shower GooseMobile Water Heaters, Filters & Pumps 8 01-01-2017 07:34 PM
Trying to decide on floor insulation or none at all perryg114 Repairing/Replacing Floor &/or Frame 1 09-20-2011 01:52 PM
None Yet :: 1965 Airstream Ambassador blanbowski Airstream Registry Discussions 0 08-19-2011 08:31 AM
Replaced running lights... none of them work! tde318 Lights - Interior & Exterior 27 10-09-2008 07:44 AM
