Old 05-15-2015, 02:34 PM   #1
1965 mustang's Avatar
Stoughton , Wisconsin
Hot water on the cold side.
I am getting hot water on the cold side. I replaced the by pass valve, I still have a problem. I'm thinking the cartridge in the shower or sink since they are single lever. Any help would be appreciated!
1965 mustang is offline   Reply With Quote
Old 05-15-2015, 03:15 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I would concentrate on the by pass valve and it's plumbing.
If it is an after market 3 valve system I would assume the center valve is not in the off position. Does it run hot for more than a few seconds a any faucet? If it is a short duration effect and the center valve is open that may just be migration through that valve.
2004 Excursion 4x4
Old 05-16-2015, 04:12 PM   #3
I replaced the by pass valve with a shark ball valve fitting. It is a three valve system, but it shows it in my airstream manual. I don't think it's after market.
Old 05-16-2015, 06:52 PM   #4
HowieE's Avatar
Images: 12
Are you sure the hot water heater is reaching full temperature before shutting off. A weak high limit switch would keep it from reaching full temperature. That is the thermostat. I would confirm the heater is reaching the limit setting before going further. Use an infrared thermometer and compare yours with someone else's heater.
Replacing the ball valves one for one should not cause any problem.
Modern shower valves may have a limit setting so kids can not burn themselves if left alone.
2004 Excursion 4x4
Old 05-16-2015, 07:25 PM   #5
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Chances are the problem is caused by cross flow. Probably the shower cartridge, but could also be the one on the sink faucet.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 05-18-2015, 03:38 PM   #6
2015 28' Flying Cloud
Newtown , Pennsylvania
Make sure the outside shower valves are closed.
Bruce
AstroBruce is offline   Reply With Quote
Old 05-18-2015, 04:19 PM   #7
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Depends on the faucet, it could be the problem, mine can be changed from hot to cold on left or right depending on how it is put back together.
Heat Pump - How cold its too cold? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-09-2014 06:03 PM
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 01:08 AM
Hot Water from Cold Valve txhippiefish Fresh Water Systems 26 04-03-2011 11:05 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 06:58 PM
