Old 10-03-2011, 01:42 PM   #1
Autumn Ridge Dr , Texas
Hot water line
I just bought a 1991 Excella 1000, 34', but when I hooked up the water, I had a problem. After tracing the problem down, I have a parted hot water line, down stream of the water heater but up-stream of everything else. Is there a schematic available of the hot water system?
pacejamr is offline   Reply With Quote
Old 10-03-2011, 02:03 PM   #2
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
If you can locate the service manual for your unit, it should give you a clue.
Are your water pipes copper??? Bet they froze..Worse comes to worse pipe air or water backwards from a fawcet, see where it comes out.
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Old 10-03-2011, 02:42 PM   #3
The pipes are plastic. It comes out somewhere between where it goes onder the floor towards the kitchen area and makes the turn near the pump. I have a service manual for the years 91,92 & 93, but it doesn't have a schmetic of the piping and where it runs. My guess is that they either froze or a creature chewed thru them while it was un-used for two years before I bought it.
Other than that, it is great.
1968 Airstream hot Water and Furnace mpovah 1959-69 Tradewind 6 03-16-2012 11:14 AM
Any hot water pumps out there? 3 Dog Nite Water Heaters, Filters & Pumps 14 07-05-2011 12:38 PM
120 vs 140 degree hot water darryl97420 Water Heaters, Filters & Pumps 3 05-24-2011 05:52 AM
'74 Trade Wind..broken water line, continued Ameliasdad Fresh Water Systems 1 04-07-2011 01:10 PM
Hot Water from Cold Valve txhippiefish Fresh Water Systems 26 04-03-2011 11:05 AM
