Old 12-19-2008, 09:43 AM   #1
2009 28' International
Columbia , Illinois
Hot water heater won't light. :(
Aloha all:
We have a 2009 28 ft International. The propane hot water heater won't light. It worked two weeks ago, now nothing. We followed the directions and turned it off and tried again after 5 minutes, still nothing. Any suggestions on what we should try next?
sinjin
Oh, and we do have propane. Just filled both tanks and the propane heater and gas burners on the stove are both working.
sinjin is offline   Reply With Quote
Old 12-19-2008, 09:51 AM   #2
cameront120's Avatar
1972 25' Tradewind
Is it an electric start or a regular pilot light model?
North Vancouver, BC
Old 12-19-2008, 11:13 AM   #3
Columbia , Illinois
It's electric start, but after driving down the road for an hour we tried it again and it started. Very weird.
Old 12-19-2008, 04:11 PM   #4
2004 25' Classic
West Chazy , New York
Did you get an "attempted light"? I think there are three tries before the red light comes on which requires a re-set of the switch. If you are at the water heater outside you can verify this. Mine will do several flame outs before it stays lit, but then it is fine thereon. I have yet to determine the cause, perhaps air in the gas line. Try cleaning the 12V connections on the water heater if you experience this again. Also make sure there are no insect webs/nests in the air tube, and that the air mixing sleeve is adjusted properly.
Ron
2004 Classic 25 - The Silver Sausage
2008 Silverado LTZ CC 2500 4x4 Duramax - Brutus
WBCCI 2623
romap is offline   Reply With Quote
Old 12-19-2008, 04:27 PM   #5
2011 25' FB Flying Cloud
Anywhere & , Everywhere
This is a very common problem with late model Airstreams. The usual advice is to clean the 12V connector but in my case that didn't work. Mine would work one place and then wouldn't work the next. And over and over. Was at Jackson Center last summer and they couldn't figure out what was causing the problem. They ended up replacing several parts and it now seems to work fine but I have no idea which of the replaced parts was causing the problem.
Al - K4GLU is offline   Reply With Quote
Old 12-19-2008, 04:40 PM   #6
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
My guess is the battery may have been low... And once down the road it recharged the battery? Just a guess!
Vin...
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 12-19-2008, 04:53 PM   #7
1972 25' Tradewind
Vin...
Yep this is very likely. Anotherpossibility is too many 12 volt fixtures running at once. This is where mine gets hung up. If I have too many 12 volt lights going, the water heater won't start. Once I turn off a couple of lights, it starts right up.
North Vancouver, BC
Old 12-19-2008, 06:14 PM   #8
vinstream's Avatar
Yes having many 12volt items working will do the samething! There is a wand with in the heater and if there is to little air moving through the system the wand will not trip the circut and the heater will not light! On that point the samething will happen when the fan motor is on it last leg or I have found this at very high alt over 10,000 feet!
Vin...
www.VINSTREAM.com
WBCCI # 1962
Old 12-19-2008, 07:13 PM   #9
Columbia , Illinois
Thanks for all the replies. The battery was fully charged and we were on shore power when we couldn't get it to light, parked in the campground. We finally just heated water on the stove to do the dishes. We don't use a lot of electrical stuff when we camp.
But thanks to you guys we have some things to try if it happens again.
Old 12-19-2008, 08:04 PM   #10
stowaways's Avatar
2007 27' Safari FB SE
1969 31' Sovereign
Ft. Worth , Texas
And yet another theory, same thing happened to us recently. Turns out one of the wires had come loose in the switch on the wall. A couple of twists of a screw driver and we were back in business. Happy camping!
stowaways is offline   Reply With Quote
Old 12-19-2008, 08:32 PM   #11
Chief's Avatar
Fort Walton Beach , Florida
I have had water heater problems on two different late model trailers.....a 2007 20' Safari SE, and our current 2008 25' Safari SE.
The '07 went through two circuit boards during the six months we owned it. When one of those babies goes out, you're not getting any power to the ignitor and the only fix is replacement (simple, but not always convenient).
Our '08 had the bad habit of not igniting at the worst possible time......during or after a rainstorm. The last time it happened, I was outside (standing in water) with a hairdryer trying to dry everything off. After returning home, I cleaned each and every connector and applied some dielectric grease to the fittings. Since then, it has neve failed to ignite.
I would guess that Sinjin's problem is a loose connection, or poor ground. Cleaning/tightening all the connections may fix the problem.
Ron
Chief is offline   Reply With Quote
Old 12-19-2008, 08:38 PM   #12
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Since you just filled both propane tanks, could you have run out of propane and not known it? Maybe the lines were air bound or maybe just one air bubble. Driving could dissolve the bubble into many little bubbles so that propane could get to the water heater. If the water heater is the last appliance to get propane, it can be the last thing to light. We've run out of propane and our furnace is the last thing, so lighting the stove brought gas closer to the furnace so it had a chance to light. You heated hot water on the stove and may have moved the gas along. I don't know where the water heater is on a 28' and tracking the lines underneath the trailer can show you what gets gas first, next and so on.
Gene
Old 12-19-2008, 09:31 PM   #13
imeynstein's Avatar
Texarkana , Arkansas
OHHHHHHH!!!!!!!!!!!!! Man!!!! I attempted to light my 1974 Sovereign only to experience a big "BOOM"....Luckily, I did not blow up!!! I removed my old Suburban and am looking for a replacement, but things are SOOO expensive and I am about ready to give up...I also need an awning, but the prices are outrageous....I am about ready to sell my 1913 home--historical--in Texarkana so I can go traveling full time...But my 1974 needs a lot of TLC...My husband tells me that my AS is 'my project', and he is 'out of it'....So, it is up to me to do it all....My AS is paid for and I feel that with today's economy, that at least I own something!!!---My husband does not share the enthusiasm that I do......So, I need as much advice as possible so I can work on my baby as much as possible while I am not working.....
HELP!!!
imeynstein
imeynstein is offline   Reply With Quote
Old 12-20-2008, 07:09 AM   #14
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Aloha Mr. Hand.
Why would you need to light the heater if the water is already hot?
Originally Posted by sinjin View Post
Aloha all: We have a 2009 28 ft International. The propane hot water heater won't light.
Sorry, I just couldn't pass this one up.
Old 12-20-2008, 09:25 AM   #15
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Originally Posted by Silvertwinkie View Post
Aloha Mr. Hand.
LOL! You beat me to it. I was going to explain the water heater wouldn't turn on until the hot water got cold again (there's no such thing as a hot water heater--a water heater heats cold water).
Maurice
Hot Water tank won't light Larry Salsma Furnaces, Heaters, Fireplaces & Air Conditioning 0 10-16-2007 08:17 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
How to light hot water tank? Dan S Water Heaters, Filters & Pumps 8 05-30-2007 09:53 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 08:07 PM
hot water heater Mary Water Heaters, Filters & Pumps 2 08-12-2002 09:15 AM
