Old 08-25-2002, 07:44 AM   #1
Question Water Heater Replacement
I own a 1976 Airstream International rear bath trailer which has a leaky hot water tank. The heater is a Bowen G-10-B. The height of the compartment entrance is 16 1/4", the width is 16". Depth is about 16" at the top, and curves around to about 20". I need to replace the heater.
I checked with some local dealers in my home town and all say that Atwood-Bowen no longer makes this unit.
Does anyone have any ideas?
Thanks.
Robert
rpwx is offline   Reply With Quote
Old 04-23-2014, 01:25 PM   #2
Toms River , New Jersey
I've been helping my parents search for a new RV and there is a place near us called Colonial. They have a section on their site dedicated to parts. Maybe they have something that will help you?? They have a bunch of stuff on there. I am not super knowledgeable on parts as I am still learning but check it out. I hope this helps! Colonial Airstream - New Jersey Airstream, Parts, New, Used, Wholesale, Retail, Travel Trailer
RoxanneQuick is offline   Reply With Quote
Old 04-23-2014, 01:43 PM   #3
Ottawa , ON
Thanks.
Robert
Bowen was bought by Atwood, but the Atwood appears to be easily found. Camping World for example, has the 10 gallon one on sale.
Atwood Water Heater - 10 gal LP - Atwood Mobile 94180 - Water Heaters - Camping World
However, their website also says that inventory is tight. Call around, you'll find them. I would buy the version that has the remote ignition (you can turn it on and off from in the trailer).
Note: you may very well find that the gas supply comes in at a different spot on the water heater, and the the trim at the bottom of the opening needs to be removed; they didn't stay unchanged over the last 40 years.
ps: they are water heaters. Not 'hot' water heaters. Why would you heat hot water?
Propane Heater or Instant water heater valontjej Plumbing - Systems & Fixtures 1 04-09-2012 08:56 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
