Old 04-03-2019, 04:55 AM   #1
Yaphank , Arizona
Hot water heater problem
After spring startup I'm only getting warm water from the fixtures the bypass valve is open. I can hear the water heater kick on but I'm getting only warm water. I have 2017 25 foot rear bedroom queen any suggestions I don't know where the mixing valve is located or what it looks like to tap on it.
scroon is offline   Reply With Quote
Old 04-03-2019, 09:53 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Shouldn't the bypass be closed?
CRH is offline   Reply With Quote
Old 04-04-2019, 02:51 AM   #3
Long Island , New York
Was your AS winterized? If so, the technician/mechanic is the most direct feedback IMO. I would look under the bed, the bypass valve is attached to the water heater. Find the heater inside one of your exterior mechanical space doors, and work backwards from there to locate the valve.
Check your owner's manual for the location and function of your mixing valve.
Guessing your mixing valve is open, allowing the cold water supply to the water heater to mix with the hot water coming out of the heater.
See diagram in last post.
Good luck,
Peter
Old 04-05-2019, 04:16 PM   #4
Yaphank , Arizona
The hot water heater is not bypassed I turned the valve to fill the water heater. The water is starting to get hotter but not scalding hot I'm thinking there is still air in the lines.
Old 04-05-2019, 07:06 PM   #5
In your Airstream, can you see the three valves shown in Post #2?
. . . and what is the position of the three valves? The upper and lower valves should be open [handles over and parallel to the pipe], and the middle valve should be closed [perpendicular to the pipe]. Do your valves look like the top part of this image? If the middle valve is open, close it and see what happens.
Earlier you said in Post #1:
. . . I don't know where the mixing valve is located or what it looks like to tap on it.
Are you now able to see your valves?
Peter
PS -- If you have opened all your hot/cold sink, shower, and toilet faucets etc. [and water ran out with no air], there is no air left in your lines.
Old 04-05-2019, 07:21 PM   #6
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
. . . and what is the position of the three valves? The upper and lower valves should be open [handles over and parallel to the pipe], and the middle valve should be closed [perpendicular to the pipe]. Do your valves look like the top part of this image? If he middle valve is open, close it and see what happens.
Peter
PS -- If you have opened all your sink, shower, and toilet faucets etc., there is no air in your lines.
The 2017 AS doesn’t have the three valve bypass arrangement like earlier years. There is only one valve to turn to move it from bypass to use mode.
They can be damaged with too high air pressure when winterizing. The mixing valve doesn’t have a stellar reputation for longevity and may need to be replaced. Some technicians recommend removing the mixing valve and reverting to the three valve system. If this is done the thermostat in the water heater should be replaced with a lower temperature version. You will also reduce the volume usable hot water (6 gallons vs virtual 9 gallons).
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 04-05-2019, 07:26 PM   #7
Thanks Ray, good points.
scroon, sorry for the mix-up. Good luck in the O. R. [see next post ]
Peter
Old 04-05-2019, 07:27 PM   #8
Yaphank , Arizona
I don't have the three valve system just the one bypass valve I hope I don't need a bypass surgery
Old 04-07-2019, 01:59 PM   #9
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Correct the 2017 only has a single valve for the hot water heater feed, no more 3 valve bypass like my 2008 had.
Having the same issue with my 2017 ‘30. De-winterized today. Spurt of very hot water then just warm / cold flows with reduced pressure as compared to the cold line.
Traced issue back to the Atwood mixing valve ar the rear of the hot water heater.
Pain in the but need to get a new mixing valve, remove the dinette bench and some other trim, replace and put it all back together.
I’m under warranty so hoping airstream can just send me a new valve and I’ll do the work myself rather than waiting in line 3 months at the dealer only for them to mess something up.
New mixing valve is about $125 bucks if you are not under warranty. Here is a picture of the failed mixing valve.
wulfraat is offline   Reply With Quote
Old 04-07-2019, 02:33 PM   #10
Yaphank , Arizona
Ok I'll will try that
Old 04-07-2019, 04:08 PM   #11
Malia20's Avatar
2017 20' Flying Cloud
Oriental , North Carolina
Warm water
Check your outside shower. I have not experienced this but was warned during my dealer walk-through...If the outside shower hot & cold valves are open and the water turned off at the shower head (in which case little or no water is flowing), you will only get warm water anywhere else in the trailer. Something about the hot & cold valves being open allows the hot and cold water to mix producing only warm. It's a quick fix if that is the problem.
Good luck.
Malia20 is offline   Reply With Quote
Old 04-07-2019, 04:45 PM   #12
wulfraat's Avatar
Good luck.
Correct, part of the troubleshooting process. My outside shower faucets were closed but good call out.
Old 04-08-2019, 10:40 AM   #13
Yaphank , Arizona
Will do thanks guys
Dewinterization problem with hot water heater vakathy Water Heaters, Filters & Pumps 33 10-04-2016 10:57 AM
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
Hot Water Heater Problem Solved Larry71 Water Heaters, Filters & Pumps 5 04-19-2009 12:29 AM
