Old 03-21-2010, 01:51 PM   #1
St. Augustine , Florida
Unhappy Hot Water Heater pilot light will not stay on
My 1988 Atwood water heater seems to keep turning off it's pilot light.
Why is this happening?
I yesterday replaced the main burner because it so old and rusted.
Any help would be apreciated.
Thank you,
Patrick
Patrickf is offline   Reply With Quote
Old 03-21-2010, 01:59 PM   #2
nord
Ron Davis's Avatar
1996 25' Excella
Cropwell , Alabama
patrick
make sure you have a good conection at the thermo couple this is a mechanical conection
good luck
Ron Davis
Ron Davis is offline   Reply With Quote
Old 03-21-2010, 01:59 PM   #3
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Patrick,
Does the pilot light hit the thermocouple enough to keep the solenoid valve open and supplying the pilot with gas?
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 03-21-2010, 02:07 PM   #4
nord
Ron Davis's Avatar
1996 25' Excella
Cropwell , Alabama
Yes the thermocouple senses the heat from polit and sends milivoltage to gas valve telling it to light or stay light your thermocouple mabe going bad?
Ron Davis
Old 03-22-2010, 10:36 AM   #5
120 inside wiring
Thanks to ALL for your but I have to be redirected now. Out of nowhere my 120 outlet for the TV stopped working.How do they wire the inside of an RV for 120? any help
Old 03-22-2010, 11:00 AM   #6
DEITZ645's Avatar
Start Simple
Patrick,
Before you dive into wiring, check that you have 120V to other outlets and also check your fuses and circuit breakers.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Water Heater Pilot Light? ronsgto Water Heaters, Filters & Pumps 12 04-13-2008 07:42 PM
Water Heater Pilot Won't Light SteveH Water Heaters, Filters & Pumps 11 10-20-2007 06:50 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater pilot light help? PolisherGuy Water Heaters, Filters & Pumps 5 05-13-2006 08:41 AM
pilot light on water heater kthomson Water Heaters, Filters & Pumps 2 12-30-2003 08:38 PM
