Old 05-06-2016, 10:39 AM   #1
Sacramento , California
Hot Water heater indicator light
Question to everyone. It the hot water heater light replaceable or does the switches also have to be replaced. I took it out and it appears to be all one unit. It is on a 2015 Flying Cloud 27fb.
Thanks for any help.
Stan
stanwirth is offline   Reply With Quote
Old 05-06-2016, 10:49 AM   #2
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Not knowing exactly what is going on, are you concerned that you HW light is not on?
If you're using electricity to heat your water, it will NOT be illuminated.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 05-06-2016, 10:49 AM   #3
2016 30' Classic
Hilliard , Ohio
On my unit the light blinks once when I turn on propane. It says off and only lights up if there's an ignition fault. It might be fine.
2016 Classic
2010 Ford F-150 Lariat
jeff4506 is offline   Reply With Quote
Old 05-06-2016, 12:12 PM   #4
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Mine doesn't blink but comes on if propane ignition fails. No light on when using 120v.
Kelvin
Old 05-07-2016, 10:50 AM   #5
2016 27' International
Larkspur , Colorado
I just watched the video on this as we were breaking in our new 27 fb. The light only stays on if there is a fault and the heater does not ignite.
MHammy is offline   Reply With Quote
Old 05-07-2016, 11:29 AM   #6
Long Island , New York
Stan
Welcome to the forum!
Your Owner's Manual should have information about when the light goes on and off -- on p. 5-17 [PDF p. 51/116]:
https://www.airstream.com/wp-content...Cloud_2015.pdf
Old 05-07-2016, 01:45 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Stan
Why would you want to replace it? Are you sure it isn't working?
Old 05-07-2016, 10:11 PM   #8
Thanks for the responses. What ya'll said fits my scenario. My previous unit indicated that it was working by the red light being lit. Sort of got suckered in on that one.
Thanks for the info and help.
Stan
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
Hot water heater "on" indicator ideas? Alphonse Water Heaters, Filters & Pumps 3 07-10-2015 08:47 PM
Water heater Indicator light carver 1 Water Heaters, Filters & Pumps 9 01-21-2014 10:16 AM
Black Water Light Indicator & Water Heater problems SGM ADAMS General Repair Forum 9 04-17-2012 05:18 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
