03-03-2018, 10:15 AM
2018 30' Classic
Arlington
, TX
Hot Water Heater in a 2018 Classic
Is anyone else having problems with their hot water heater? We are on the Alde system. We did a short trip in December and it worked fine.
We stopped at an Airstream dealership yesterday because it wasn't working. The service manager bled the system and we had instant hot water. We were told that the radiant heat had to be on and he said you do not need to have the radiant heat on.After bleeding the system it worked and the radiant heat was not on. We are very confused right now. Sometimes we have hot water and sometimes we don't . We definitely have it if we put the shower booster on (switches to gas when the booster is on). If we take it off the shower booster we loose the hot water.
Anyone have any suggestions on how to fix the problem?
Thank you,
Montanachick
03-05-2018, 11:35 AM
2018 30' Classic
Arlington
, TX
Alde hot water heater on 2018 Classic
Montanachick again. We have been in touch with our dealership the past couple of days and talking to them this morning they received as ervice bulletin #173, which applys to Airstream 30 and 33 Classics built between 1-31-17 and 11-2-17, serial number ranges 538263-542982.
The bulletin states that these airstreams built with in the above period have possibly been wired wrong. In our case it is wired wrong. The wires need to be switched on Port 3 behind the Firefly system.
Check out the bulletin for more details.
montanachick
09-21-2018, 02:10 AM
Phoenix
Same issue .......please help anyone
Thank you,
Montanachick
09-21-2018, 11:25 AM
Airstream Ambassador
Jackson Center
, Ohio
Thank you,
Montanachick
Hi montanachick,*
We're very sorry to learn about the issue you are having. If you are still having issues, please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
09-21-2018, 11:28 AM
Jackson Center
, Ohio
Hi bradjenkins,*
We're very sorry to learn about the issue you are having. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
Thank you.*
09-21-2018, 01:15 PM
2018 30' Classic
Ivins
, Utah
Just to answer one of your questions... you do not have to have radiant heat on to get hot water. On the main page of the main firefly panel are two buttons- one for water heater, one for radiant heat. Only the water heat needs to be on for hot water. The shower boost button will give you additional hot water for showers.
The radiant heat button simply circulates heating fluid to the room radiators.
12-29-2018, 04:03 PM
2018 22' Sport
Airstream Coach - Other
ancramdale
, New York
water heather
22 ft2018 safari sport bambi..just noticed that when i turn on the hot water heater it drips a steady drip ...that red plug was a bit out,puched it back in place,still drips ?????will try to post photoits on the side of the release valve,the one you pop uo when draining the tank
12-29-2018, 04:11 PM
2016 30' Classic
Hinckley
, Ohio
I would lift the lever on the relief valve and let it snap back down. This clears it out and reseats it.
The red ring is only a female thread protector.
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
12-29-2018, 04:19 PM
2018 22' Sport
ancramdale
, New York
thanks... i will try.i can do that... when daylight comes...but i still can not post photos successfully!
12-29-2018, 05:11 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Why does hot water need a heater? 😂
12-29-2018, 05:14 PM
2012 27' Flying Cloud
W
, New England
Originally Posted by ROBERT CROSS
Why does hot water need a heater? [emoji23]
[emoji631]
The same reason you put toast in a toaster. [emoji3]
12-29-2018, 05:21 PM
2007 22' International CCD
Corona
Actually, I generally put bread into a toaster first. Then it produces toast...
Yeah, pedantic darn Engineer type.
The glass is too big.
12-29-2018, 05:23 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Yes... but I don't put bread that's already toast in a toaster, why would you have to heat hot water in a water heater if it's already hot. 🥴
Ahhh, it's a hotter water heater, got it.😉
12-30-2018, 02:14 AM
W
, New England
Surely you both saw the irony in my comment?
(A perfect response here would be, Yes I did - and don’t call me Shirley!)
[emoji3]
12-30-2018, 05:27 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Of course...but this IS the AS Forums after all where...
“Nothing is so disappointing as unappreciated sarcasm.” 😉
RLC
12-31-2018, 06:25 AM
2018 22' Sport
ancramdale
, New York
i did and it worked...popping up the lever let out a gush of water,i let it run a bit then snapped back down..... it worked..
thank you very much M.V
12-31-2018, 06:51 AM
2016 30' Classic
Hinckley
, Ohio
Glad to here it was only debris under the seat. You can also do this to renew the air cushion with in the tank.
01-01-2019, 08:23 AM
2018 30' Classic
Arlington
, TX
Update on having hot water!
Montanachick here,
Sorry for not posting this before now but we finally figured out what was happening with the hot water button! After talking to Spencer at Alde, we figured out that the reason we were not getting hot water was because the circulating pump was consistently. When the system is being filled with glycol, the pump needs to be on to get it through the system. Unfortunately, it was never switched over to the other button (forget what it's called). As soon as we switched it over we had hot water in 10 minutes! The circulating pump should only be on when the heat comes on.
Happy New Year to one and All !!!
02-04-2019, 10:29 AM
2018 25' Flying Cloud
St James
, New York
Hi I have a 2018 flying cloud my question can i turn on my hot water tank when only using city water, not from fresh water tank....tks
05-04-2019, 08:28 AM
2018 22' Sport
ancramdale
, New York
propane.....hot water tank
i just had my propane tanks filled,now i can not get any hot water,i heather kicks on,red light goes off system shuts down???????why??it worked perfectly fine till i filled the propane tank.?????help!!!!
