Old 08-28-2017, 04:57 PM   #1
1967 24' Tradewind
Flagstaff , Arizona
Hot Water Heater Gas Valve
I am replacing my hot water heater gas valve on my 1967 Trade Wind. Does anyone know if the Atwood 91602 is the right replacement valve? Also, does anyone know where to find the main burner assembly or something similar that can be modified to work? One final question. Does anyone know where to find a replacement access compartment door for the heater valve assembly? Thanks!
jbobarino3 is offline   Reply With Quote
Old 08-28-2017, 06:36 PM   #2
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Is there a reason your trying to save your old heater? It makes more sense to replace it with a new unit. By the time you buy all those parts and put them in, it will be more cost effective to replace the whole unit.
If you could have a superpower, what would it be?
I chose America
Bigventure is online now   Reply With Quote
Old 08-29-2017, 10:09 AM   #3
1967 24' Tradewind
Flagstaff , Arizona
Good question. I don't know. I have no idea what model I currently have. Do you have a recommendation for a new replacement? Thanks!
Old 08-29-2017, 10:50 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Can you post a pic?
Atwood 6 gallon water heaters sell for less than $300. These are "pilot" models. No electronics required.
You coach may have had a Bowen WH which is the easily replaced with an Atwood.
Old 08-29-2017, 11:34 AM   #5
Boxite's Avatar
2008 22' Sport
I replaced my Atwood WH LP valve with this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The seller and Atwood both confirmed it was the correct part and it was simple job. Contact the seller/atwood directly if any question instead of those of us who may not have the same heater, IMO.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 08-29-2017, 12:51 PM   #6
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
To replace the tank measure the old opening. Then buy the size that fit it the best. I think the Atwood's would fit. You may have to trim the opening a little to make it slightly larger. Easier than patching it back to make it smaller. They sit on the floor of the trailer. Repiping is easy.
I would never start replacing parts on an old heater. Unless I knew that that was the only thing wrong. Because as soon as you do something else goes and before you know it your $500 in and have spent a ton of time on it. And at the end of the day it's still an old heater that could spring a leak.
You can also recover some cost buy selling the old cover in the classified.
I chose America
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
1965 Safari gas manifold, valve and new water valve avdindenver Airstream Classifieds 0 12-09-2015 09:53 AM
Hot Water Heater By-Pass Valve Stuck RedDogBullet Water Heaters, Filters & Pumps 4 06-12-2012 10:00 PM
Suburban Hot Water Heater Smell/Gas Valve SafariSS Water Heaters, Filters & Pumps 2 10-23-2011 06:48 PM
Leaky Hot Water Heater, funky gas valve KC aravanner Water Heaters, Filters & Pumps 5 03-25-2010 07:21 AM
