Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 06-04-2006, 08:41 PM   #1
glacierrunne
Profile:
hot water heater flare up!!!
Got most of my plumbing leaks fixed so decided to light the hot water heater.It's a 6 gallon Atwood. The pilot light was easy but when I turn the knob to ON ,it FLARED up by the slide air shutter. I was able to turn it back to pilot right away---- soooo no harm but I've got all the manuals out and want to know if there is any help out there on this one. I've got a 1980 Caravelle. Thanks, Don
glacierrunne is offline   Reply With Quote
Old 06-04-2006, 08:52 PM   #2
peegreen
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
Try taking off the burner tube and cleaning it out. A favorite place for spider webs and nests causing gas blockage and flare ups as you observed.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 06-04-2006, 08:54 PM   #3
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Sounds like the LP delivery system needs a thorough cleaning. Take everything apart, clean the burner and orifice, all tubing, etc. It should take care of the problem unless you have a propane leak somewhere else. Also, be sure that the air mixing opening is properly adjusted.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
lewster is online now   Reply With Quote
Old 06-04-2006, 09:01 PM   #4
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
yup
sounds like bugs in the pipe.
john
you call them ferrets, i call them weasels.
Old 06-04-2006, 10:08 PM   #5
glacierrunne
Profile:
Thanks guys! That makes sense, since the trailer has not been used for several years. I have two more plumbing leaks( hate those gray fittings used in the 80's) to fix then will clean burning tube. I'll let you know what I find! Thanks again, Don
Old 06-05-2006, 09:50 PM   #6
glacierrunne
Profile:
Big Time Spider web, cleaned it out and everything works just Fine! Thanks again for the Tip. Don
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Cranky water heater. wyhjr Water Heaters, Filters & Pumps 5 12-02-2002 09:01 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
hot water heater Mary Water Heaters, Filters & Pumps 2 08-12-2002 09:15 AM
