Old 05-12-2004, 11:50 PM   #1
Oregon City , Oregon
Rivet Hot Water Heater Dead in Oregon
Well Camping World took one look at my old Bowen and said it was rusted they wouldn't touch it. The Hold down button was stuck so I forced it and it got stuck in. Then the cap came off and so I have to open the Uniflow cover to push the button out. I guess this is a no-no. Well, my 66 Tradewind has no hotwater and I suspect noboby will touch it. Is it worth replacing the original setup and is an Airstream Dealer the only one daring enough? I have read here that the RV500 is the only way to go. Also I need recommendations on the replacement of the original Suburban Novent Furnace. NT20 the right one? Used ok?
Help in Portland OR.
Armorhotdog
66 Tradewind 24 twin w/ bunks!
91 Landcruiser
90 F-350 460 Centurion SUV (coming tomorrow!)
Armorhotdog is offline   Reply With Quote
Old 05-12-2004, 11:59 PM   #2
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Lots of us have replaced our original bowen heater with a new Atwood. For the most part they just slide right in. The gas line and water lines may need some modifications. I would think any competent RV repair place should be able to handle it. Although Camping World seems to have an adverstion to AS expecially older ones like ours.
You can follow the link in my signature and see some info I posted about replacing mine.
Good luck.
-Tim
theVAP - Airstream Podcast
Old 05-31-2004, 09:51 AM   #3
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
We just bought a 66 Safari and it had a dead water heater. The dealer that we bought it from in Indiana is an airstream dealer and they put a new Atwood right in. They made a matching aluminum flange and it looks real good. They even spray painted the door grey!
John
AYRSTRM2 is offline   Reply With Quote
Old 05-31-2004, 11:36 AM   #4
TroutStream's Avatar
Twins with Bunks?
Armorhotdog,
Am curious... Are your twins with bunks original from the factory? Could you post pics? We have a 1970 Overlander and I was thinking of adding bunks to the twins but didin't want to mess interior up too bad.
Ken.
TroutStream is offline   Reply With Quote
Old 06-17-2004, 05:47 PM   #5
Creampuff
Creampuff's Avatar
1957 22' Flying Cloud
1971 31' Sovereign
1976 29' Ambassador
Malibu , California
Images: 60
A'dog :
Don't throw out the unit wiyhout saving the covers and clips for bottom draft cover. Someone may need the cover/ shroud.
I need one clip for my '67 ! Took it off and can't find it anywhere !
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 06-18-2004, 01:40 PM   #6
1973 31' Sovereign
Portland , Oregon
Images: 22
Portland area supplier to check out...
Since you are in the Portland area you might want to check out the "RV Parts Outlet Showroom" in Tualatin. They do not install parts as far as I know but they are very knowledgable, stock a lot of different things and seem to have great prices. One of the guys that works there used to be an Airstream dealer I believe. I am working on rebuilding a 1973 31' Sovereign and found that taking out the old water heater was pretty easy. I would guess putting in a new one would be easy too as long as it will fit in the old space.
Here is their website:
https://www.rvpartsoutlet.com/newstore/nojava/index.cfm
Malcolm
malconium is offline   Reply With Quote
Old 02-16-2005, 11:06 PM   #7
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Hi AMHD, I would try Laurelhurst heating and cooling on East Burnside St. Sorry I do not have their address handy. It is about 50th ave. or so. Right now I have a 1965 Aristocrat with a Magic Chef Range. They actually had a brand new pilot light assembly there for the oven. I was amazed. I found them to be very knowledgeable. I am in the process of buying my first Airstream right now. I should be picking it up this weekend ! Yea !
Chris
C Johnson is offline   Reply With Quote
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 02:35 AM
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
tankless hot water heater imeynstein Water Heaters, Filters & Pumps 19 04-17-2004 01:58 PM
Nobody needs a hot water heater!!! Rick Alston Off Topic Forum 109 02-13-2004 09:52 PM
Lighting Hot Water Heater hhuber Water Heaters, Filters & Pumps 14 04-01-2003 09:31 AM
