Old 06-11-2012, 09:04 PM   #1
RedDogBullet's Avatar
2012 20' Flying Cloud
Anchorage , Alaska
Hot Water Heater By-Pass Valve Stuck
We are in the process of de-winterizing our 2012 20ft. Flying Cloud...finally! I went to switch the by-pass valve from the "By-Pass" position to the "In-Use" position. It won't budge. I don't want to crank on it as I am not even too sure which way to turn the valve. Any tips on how to get this thing to move? Which direction to turn it?
RedDogBullet is offline   Reply With Quote
Old 06-11-2012, 11:18 PM   #2
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
I beliee it's a 1/4 turn ball valve. If it's brass you can really push on it. Plastic not so much. The handle should have a stop on it that you can see that will give you an indication of directional turn.
Typically if the handle is facing right it will turn down.
Dan
TAC
Hope is not a plan.
danlehosky is offline   Reply With Quote
Old 06-12-2012, 09:13 AM   #3
mefly2's Avatar
2015 25' FB Eddie Bauer
Our FC20 valve is very is stiff to turn ...
Old 06-12-2012, 10:20 AM   #4
Anchorage , Alaska
Thank you for the advice. We finally got it into the in-use position.
Old 06-12-2012, 10:00 PM   #5
mefly2's Avatar
Enjoy!
