Old 05-18-2004, 04:29 AM   #1
1962 16' Bambi
Merritt Island , Florida
Hot Water heater burner
Hi,
Does anyone know where I could get a burner for a Bowen water heater, mine is missing and I cannot read the part number from it's ID tag, the lines that go to it are also missing, no sensor or line for that either.
Chris
C Ray is offline   Reply With Quote
Old 05-18-2004, 05:48 AM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Your local RV shop sells the current replacement burner for Bowen/Atwood water heaters. More than likely, it will not fit your water heater without modification. By "sensor line", I assume you mean the thermocouple. They sell that too.
Proceed carefully at this point if you plan to repair this unit. Will the tank hold water at pressure? It may be rusted out. The burner & thermocouple will set you back at least $50. Plus time to modify it if it can be modded. You won't know if the Control valve/thermostat works until you try to use it. $100 would fix that problem, but I would highly recommend replacing the water heater if that part is bad.
The perfect solution would be to find an old water heater for parts - Check with your local RV place.
Good luck,
Tom
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 03:35 AM
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 03:29 PM
tankless hot water heater imeynstein Water Heaters, Filters & Pumps 19 04-17-2004 02:58 PM
Nobody needs a hot water heater!!! Rick Alston Off Topic Forum 109 02-13-2004 10:52 PM
Lighting Hot Water Heater hhuber Water Heaters, Filters & Pumps 14 04-01-2003 10:31 AM
