Old 04-05-2008, 09:15 PM   #1
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
Hot water heater?
We need to replace the hot water heater in our 76 Argosy, and were just going to replace it with another one just like the other one, but were wondering, has anyone ever replaced their hot water heater with an on-demand one? Would that be an option, or a big hassle installing it? Thoughts, anyone? I know they are more expensive but with no tank to drain, it seems like winterizing would be easier and they would be less costly to operate in the long run.
Isadora is offline   Reply With Quote
Old 04-05-2008, 09:28 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
There are those who have installed the "tankless" water heaters. Should be made specific for RVs from what I understand.
BTW - you're going to catch grief for calling it a Hot water heater. No need to heat hot water....
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 04-05-2008, 09:57 PM   #3
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
Fine. It is not a hot water heater. Excuuuuse me. We just got home from 10 hors on the road hauling our Argosy home. Cut me a little slack here, lol!
Old 04-05-2008, 10:00 PM   #4
Fyrzowt's Avatar
2000 25' Safari
Images: 8
Sorry...just a little levity. Certainly no harm intended!
Do a search for "tankless" and you should come up with something.
Dave
AIR #15800
2000 Safari SS 25'
Old 04-05-2008, 10:08 PM   #5
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
No offense taken, I will check online for a tankless heater. Thanks
Sandy
Old 04-06-2008, 03:32 AM   #6
Baltimore , Maryland
be seated when you "look into" the price... Good luck with replacing that cold water heater. Here is my new cold water heater...
... made to look old. I went with the old fashion one. I felt a tankless would give a false sense of having unlimited water and worse yet unlimited waste water storage. I also went for the pilot light model due to me not feeling comfortable with just flipping a switch. I know that regardless, I would be walking outside to check the flame, so why not just light it as I check... see the logic?. I also went with this simple model so that no power was required to make it work.
Old 04-06-2008, 07:56 AM   #7
lewster's Avatar
Naples, FL , Hood River, OR
The only tankless water heater unit that has been approved for RV use is the RV-500 made by Precision-Temp, Inc. Welcome to PrecisionTemp.com . Others have broached the subject of usng some domestic units in their RV, but the venting requirements usually prohibit a safe and aproved installation. Remember, safety is key when thinking about installing any LP appliance in an RV.
BTW, I have an RV-500 in my CCD and have installed bunch of them in other RVs as well. I have had one in my RVs since 2000 and have never had a failure or service call on these units.
Just a word of caution......endless hot water for showers can become addictive....causing you to spend an inordinate amount of time in the shower .
Old 04-06-2008, 10:38 PM   #8
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
I think after looking at the units and the prices, we will probably just stick with a new Atwood/Bowen for our replacement. Sheesh those things are expensive! Thanks for your advice.
Old 04-07-2008, 06:17 AM   #9
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Trip from NC
Glad the Argosy is at it's new home and has an owner ready to make it into the fine trailer it should be.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 02:35 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Hot water heater Action Water Heaters, Filters & Pumps 25 07-21-2006 06:37 PM
Hot Water Heater ?????? davidh Water Heaters, Filters & Pumps 7 02-28-2006 07:25 AM
Nobody needs a hot water heater!!! Rick Alston Off Topic Forum 109 02-13-2004 09:52 PM
