Old 12-22-2007, 11:04 AM   #1
mrmossyone's Avatar
1975 Argosy 24
Collierville , Tennessee
Hot water heater.
Any advice on lighting the hot water heater? Is it just like lighting any pilot light? Thanks in advance.
Different strokes for different folks!
I never learned from a man who agreed with me.
Heinlein
mrmossyone is offline   Reply With Quote
Old 12-22-2007, 01:05 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Just one.......
After you place the gas valve into the 'pilot mode' and depress it when you light the pilot, be sure to hold the knob down for about 30 seconds to allow the plot flame to heat the thermocouple sufficiently to allow the gas valve to remain open and keep the pilot lit.
PS: The device you are describing is a 'water heater' not a HOT water heater..... as it's purpose is to heat water.....not to heat 'hot' water.
Old 12-22-2007, 03:25 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Picky, picky. We had a hot water heater in Canada. Those canucks use them a lot. Ours heated water and circulated it through the floors. Living in the best of both worlds, we had both a water heater and a hot water heater combined. Heating hot water can boost your self's steam.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 12-22-2007, 03:42 PM   #4
ScottW's Avatar
Hernando , Mississippi
Guess I'm glad Lew beat me to it. It only heats water...as Lew says. Picky, yes...correct...yes.
IMHO.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 12-22-2007, 10:53 PM   #5
mrmossyone's Avatar
1975 Argosy 24
Thanks for advice, sounds like lighting just about any pilot light. Please forgive my unseemly breach of water heater etiquette.
Heinlein
Old 12-23-2007, 12:44 AM   #6
greywolf's Avatar
1968 24' Tradewind
Crestview , Florida
Well, initially I have a water heater, then after a while it does become a hot water heater.
This happens because my wife and daughter want me to keep the thermostat set way over to the "Hot" setting that after the initial heating of the water, it cools in the tank by about 5 degrees then the heater blasts back on again while the water is (in my humble opinion) still hot.
I may need to replace the thermo coupler however because I have to hold the pilot knob longer than 30 seconds, more like two minutes, before the pilot will remain lit on its own.
The one dude needs to be 'Streamin more often, then he wouldn't sweat the details.
Disclaimer: Don't take my statement of 5 degrees as absolute, I'm using the SWAG method.
Courtesy parking-- water, elect. and wi-fi.
To those who are about to Stream-I salute you!
greywolf is offline   Reply With Quote
Old 12-23-2007, 08:16 AM   #7
water heaters
Since Airstream is the pride of the RV industry, they have never used "hot water heaters."
They do use "cold water heaters."
So it is said, you never heat hot water, you only heat cold water.
Semantics, hmmmm.
Old 12-23-2007, 11:42 AM   #8
Excella CM's Avatar
Venice , California
Of course, "hot" is a matter of degree.
Old 12-23-2007, 02:26 PM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs down Hot....
[quote=Excella CM]Of course, "hot" is a matter of degree.[/quote
We newer owners can't be trusted to control our own "cold" water
heaters, so whatever the degree that's as hot as it gets...
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Hot Water Heater 1967Caravel Water Heaters, Filters & Pumps 4 09-05-2006 11:52 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 08:07 PM
Nobody needs a hot water heater!!! Rick Alston Off Topic Forum 109 02-13-2004 09:52 PM
hot water heater Mary Water Heaters, Filters & Pumps 2 08-12-2002 09:15 AM
