Old 09-05-2006, 05:08 PM   #1
Member
1967Caravel's Avatar
1967 17' Caravel
Creve Coeur , Missouri
Hot Water Heater
what brand of hot water heater is a direct replacement without to many modifacations in a 1967 caravel. would an atwood or a suburban be a better choice.
1967Caravel is offline   Reply With Quote
Old 09-05-2006, 07:33 PM   #2
1960 24' Tradewind
santa barbara , California
Hello 1967Caravel ,
Our 60 trdwnd had the bowen as they all did ,we used a 10 gallon suburban
unit,it fit in the opening very well ,I did have to redo the ducting to match the old shroud ,as I definately wanted it to be retained .That took some
fabricating to do ,but the results were worth it .nothing will be an exact replacement ,but you may get reponses from folks with Atwood installs ,and the layout of the heater is more like the bowen ie: controls and ducting .We
have the pilot ignition only ,no electric .It is possible the atwood will be a
better oem type fit up ,but others will respond here to you about that.
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 09-05-2006, 09:26 PM   #3
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
Isn't Hot Water Heater an oxymoron like Jumbo Shrimp. Shouldn’t it be called a Cold Water Heater?
I used a Suburban in my Safari
Safari64 is offline   Reply With Quote
Old 09-05-2006, 09:48 PM   #4
StingrayL82's Avatar
San Angelo , Texas
Images: 37
We installed an Atwood DSI propane/110v and love it...fit like a glove.
Frederic & Brooke.
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 09-05-2006, 11:52 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
In the 'trade' it's simply called a water heater.......which is exactly what it does.....it heats WATER, not hot water. Although one might get a wild hair and say that after initial start-up, the water in the tank is hot (or warm) and the unit fires, making it then heat the already HOT water in the tank.
Anyway, whatever it's called, one gets the point .
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
Cranky water heater. wyhjr Water Heaters, Filters & Pumps 5 12-02-2002 09:01 PM
Hot Water Heater Exhaust Damage Road Ruler Water Heaters, Filters & Pumps 11 11-11-2002 02:27 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Leak in hot water heater tank Rog0525 Water Heaters, Filters & Pumps 8 06-10-2002 02:10 PM
