Old 05-23-2015, 03:05 PM   #1
1988 34' Limited
1988 34.5' Airstream 345
Phoenix , Arizona
Hot Water heater
1988. Airstream motor home 345 //classic
Lafayette is offline   Reply With Quote
Old 05-23-2015, 03:22 PM   #2
1988 34' Limited
Phoenix , Arizona
Oops! I wanted to say I was under the impression that my h2o heater was electrics as well as propane. If. So. I wanted to use it as electric. Is there a switch to turn on or any other ,thing. I need to do? Step by step help would be nice. No hot water....burr
Old 05-23-2015, 06:21 PM   #3
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Look at the switch to turn on the propane heat in you water heater (normally in bathroom) it has a small flame and red light that illuminates briefly when turned on then goes out when water heater is lit. There should be another switch next to it with a lightening bolt. That is for the electric element. If there is not one it was not part of the original installation. Look at the top front of your water heater where the piping is. There should be 4 wires for duel heat but only 3 for just propane. also on the bottom front left there should be a electric junction box with 3 12 gauge wires coming out (white, black, green).
Dave and Felicia
wxbuoy is offline   Reply With Quote
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 01:08 AM
Hot water heater and water pump xo1rider 2011 - 2015 International 3 10-12-2012 06:55 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 06:58 PM
