Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 08-11-2002, 10:49 AM   #1
Mary
Profile:
Question hot water heater
Need some help on our hot water heater....there is a drain plug that has an extension of about 3 - 4 inches that goes into the unit. When my husband removed it to drain the tank this extension was badly corroded and we can't tell what the original material was. Almost looks like a screen of some sort ???? The trailer did not come with the manual for the heater, but am almost certain it's from Atwood.
Mary is offline   Reply With Quote
Old 08-11-2002, 11:25 AM   #2
paul rogers
Profile:
hi. new to board. i think this may be your anode rod at least that what it is called in suburban water heaters. i think in atwood they call it a heating element. the replacement part in inexpensive and cw has them.
free to travel @last.
paul rogers is offline   Reply With Quote
Old 08-12-2002, 09:15 AM   #3
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Mary,
I believe Paul is right. If memory serves me right, the anode rods are around 6" long when new and are available for Suburban as well as Atwood water heaters. They are available at Camping World www.campingworld.com
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
Nobody needs a hot water heater!!! Rick Alston Off Topic Forum 109 02-13-2004 09:52 PM
Lighting Hot Water Heater hhuber Water Heaters, Filters & Pumps 14 04-01-2003 09:31 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
Hot water Heater DClark Water Heaters, Filters & Pumps 11 08-26-2002 06:04 PM
