Old 04-22-2004, 07:42 PM   #1
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Hot water heater
I have owned my Overlander for 3 years and have never gotten the water heater to work. It is the original unit as best as I know. There is propane to it, cause I can light the pilot. However I cannot fire off the main flame. Every other component that operates on propane works, except the water heater.
I have let the pilot light burn for over 4 or 5 minutes. (That's a long time when I sit there and hold the valve handle) Still no main flame.
So my Q's are:
Does the tank need to be totally full of water for the main flame to work? IE is there some sensor that has to be activated by a full tank to allow the flame to come on?
How do I test components to determine if the valve in fact even works at all?
>>>>>>>>>>>>>>>>>>Action
Old 04-22-2004, 09:10 PM   #2
WayWard Wind's Avatar
2004 25' Safari
Not sure when you say you hold the handle for 5-6 minutes, however it sounds as if you have an older style control with a thermocouple. If that's the case, there should be a small copper colored (looks like a wire) coming into the bottom of the control. Try tightening the nut slightly. This is where the connection is made for the main burner to work. Also how is the pilot burning against the thermocouple ( that's the other end of that copper looking wire inside the heater ) ? Yellow? It needs a clean flame to work. If your control has a red button to hold down to light the pilot, then it sounds as if your thermocouple is perhaps bad. The thermocouple is replaceable & you should be able to get what you need at a LP Co or RV store. If you're not real sure of what you're doing, then I'd suggest you have it checked by a LP service.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 04-23-2004, 06:49 AM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by Action
...I have let the pilot light burn for over 4 or 5 minutes. (That's a long time when I sit there and hold the valve handle) Still no main flame.
I take it you have to keep the button pushed in for the pilot light to stay lit? If you let go, the pilot goes out?
If yes to both, then I agree - you probably have a bad thermocouple.
Unfortunately, if your water heater is as old as mine, you will find the thermocouple & pilot light are constructed as one assembly, and at least in my case, the particular assembly is no longer available.
Oh, and running the water heater with insufficient water in it could hurt it.
Good luck,
Tom
Old 04-23-2004, 06:59 AM   #4
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Button
The Thermocouple opens main gas flow.
The button you depress for pilot lighting is not controlled by Thermocouple. It is a bypass. The Thermocouple will open the gas valve when it reaches the threshold for gas flow.
Sounds like a Thermocouple to me.
Smily
smily is offline   Reply With Quote
Old 04-23-2004, 09:43 AM   #5
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
I agree it sounds like a thermocouple being the culprit.
But you also need to check your other gas appliances, are the flames burning correctly? The control valve also has a sensitivity to gas pressure.
If everything else looks good try the thermocouple, if not look at gas pressure also.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 04-23-2004, 12:02 PM   #6
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I have always had a hard time lighting my water heater, and adjusting the flame, so I had the RV service guys look it over - they ended up replacing the burner assembly, along with the valve (which they said wasn't letting enough gas through anymore), and added a re-ignitor module. When I got it home I went to light it and barely had to hold the pilot before it took. I was amazed it made such a difference in how easy it was to light, and of course the re-ignitor takes care of the problem of holding a lighter to it while heating up the thermocouple. I might actually use it regularly this season, now that I won't have to sit out side holding the pilot button down for five minutes at a time!
Stephanie
Old 04-23-2004, 02:19 PM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Wow
Thanks for all the replies.
The reason I am a little vague on my proceedure is I am going on a trip next month and thought it would be cool to have hot water. And I have not looked at the water heater since last fall. And yes I believe you are correct, the burner is a button I push in after turning the knob to a certain position. When I release the knob/button the pilot goes out and there is no flame.
I will look at the thermocouple and the burner.
>>>>>>>>>>>>Action
Old 04-23-2004, 06:44 PM   #8
Still Working
smily's Avatar
1994 36' Classic 36
Try this
You may have already but if not,
hold the lighter directly on the Thermocouple when lighting pilot.
If your is older, I think you may have a weak Thermocouple or it may just be too far awayfrom the pilot light.
Try lighter on Tcouple and then try bending T couple housing closer to Pilot flame.
I think it will light now. Let us know.
Smily
Old 04-23-2004, 07:10 PM   #9
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
You know when I bought the trailer there was an extra new thermocouple with a pile of other stuff. I think I know where it goes.
>>>>>>>>>>>Action
Old 04-23-2004, 08:50 PM   #10
2004 25' Safari
Just a word of caution---Be extra careful if you bend the thermocouple into the pilot flame. After 35 years of working with natural & LP gas, I've seen more than once where this has been done & the pilot flame would then be strong enough to hold the main gas valve open, but not burning high enough to immediately light the main burner, until enough gas entered the chamber & then well it's not a nice happening, but does seem to clear only the burner, chamber & flue pipe, if you're lucky. If you're not real sure of what you're doing, I'd suggest having a qualified serviceperson check it over.
Best,
Bogfrog & Mr. Turbo
Old 04-24-2004, 03:16 AM   #11
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Just out of curiosity, what do you people with new AS have to do to light your hot water heater, furnace, etc? Do you just push a button and it happens? Do only us vintage owners have to sit outside in the rain lighting water heaters, and lay on our bellies in the tub lighting furnaces?
Stephanie
Old 04-24-2004, 05:59 AM   #12
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Some do and
Stefrobrts,
It just depends on what model you have installed..Even as an Vintage owner,
you can have that feature installed as well..Now you just have another Spring project~!
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 04-24-2004, 01:10 PM   #13
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Based on an hour of fiddling I think I need to replace the thermocouple. The replacement that I have with the trailer is a 24". The one on the water heater is a 12". Will the extra length make a adverse difference?
>>>>>>>>>>>>>>>>Action
Old 04-25-2004, 04:40 AM   #14
TomW's Avatar
1967 26' Overlander
..The replacement that I have with the trailer is a 24". The one on the water heater is a 12". With the extra length make a difference?
It shouldn't, but I am not an authority.
Thermocouples are devices which produce a small amount of electricity when heated. The extra length you have will induce a voltage drop, but with 12 inches, it should be negligibile.
I do know you will not hurt anything by trying the longer one, and it will probably work just fine. Just be sure to wrap the excess up in a nice circle, and tie it off if necessary to keep it from vibrating around.
Tom
Old 04-27-2004, 08:27 AM   #15
FireFighter's Avatar
bay city , Michigan
New Water Heater With AC
Last year my water heater failed the date on it 1982 so don't feel to bad other than cleaning up the water. any how i just ordered a new water heater after reading some posts i went with a 10 gallon Atwood to replace the one that was there. this time i opted to get one with LP and AC my question, is there any thing special i should now about AS wiring the fuse panel is directly above the water heater and i am very knowlegeable when it comes to home wiring but recall when doing some wiring is some of my previous boats things where a little different. that whole moving bouncing thing i guess.
FireFighter is offline   Reply With Quote
Old 04-27-2004, 08:32 AM   #16
LOST , Hawaii
Keep neutral and ground isolated, other than that it is pretty much the same.
John
74Argosy24MH is offline   Reply With Quote
Old 04-27-2004, 08:36 AM   #17
TomW's Avatar
1967 26' Overlander
...my question, is there any thing special i should now about AS wiring the fuse panel is directly above the water heater and i am very knowlegeable when it comes to home wiring ...
If you are comfortable with home wiring, you should be in good shape for the project. The only thing that pops to mind is your total current rating. If your Airstream has a 30 amp service, you may want to be careful about running the air conditioner and water heater at the same time.
Just a thought,
Tom
Old 04-27-2004, 08:45 AM   #18
bay city , Michigan
30 amp service
i understand this but aren't Travel trailers limited to 30 amp services as that is what is available at camp grounds? excuse my limited knowledge here but how do all of the new TT's have both of these? just trying to understand
thanks for the information every one.
Old 04-27-2004, 08:49 AM   #19
TomW's Avatar
1967 26' Overlander
It has been my observation that the standard is now a 50 amp service. Hopefully, more seasoned campers will confirm that better and/or new campgrounds offer 50A & 30A service at their sites.
Old 04-27-2004, 09:07 AM   #20
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The new models have electronic ignition, which means no standing pilot light. You basicly just flip a switch on in the bathroom and that energizes the system. When water temp gets low, a sparker ignites the gas.
Some units also have a built in electric heater also. This is an additional switch in the bathroom that energizes this circuit. My '01 Safari was gas only. My '04 Classic is gas and electric.
With the heat pump/AC and electric water heater, my LP usage is pretty minimal.
Jack
Jack Canavera
STL Mo.
AIR #56
jcanavera is online now   Reply With Quote
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 03:35 AM
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 03:29 PM
tankless hot water heater imeynstein Water Heaters, Filters & Pumps 19 04-17-2004 02:58 PM
Nobody needs a hot water heater!!! Rick Alston Off Topic Forum 109 02-13-2004 10:52 PM
Lighting Hot Water Heater hhuber Water Heaters, Filters & Pumps 14 04-01-2003 10:31 AM
